Engine built: woohoo!! (pics + videos)
Not a shop but a very knowledgeable mechanic from my corvette club did the build so not only did it save me a great deal of cash, but I got to watch, help and learn as well.
It all went very smoothly, the man took all the time neccessary, no rushing and did everything properly. In total we were at it for four days:
- The first day we lifted the engine and removed the old intake, heads and cam+lifters.
Four bolt main, always nice:
- The second day we thoroughly cleaned the engineblock and after that installed the new parts. Engine was in mint condition, only a small amount of carbon deposit. Other than that everything was almost like new.
- On the third day we reinstalled the engine and all the components we took off to do the lift (fan, pumps, headers, etc.).
- The fourth day was all about break-in, timing and adjusting the carb. Fired right up and not a single leak!
Man did she sound awesome!
At the end of the afternoon the moment was there: drive it!!
First drive: http://www.youtube.com/watch?v=gZwNuoMCydQ (1:04 min.)
A few sprints: http://www.youtube.com/watch?v=inkvi1vGBVQ (0:26 min.)
Still some small issues to work out though. For one the carb (EDL-1411, 750 cfm) is a tad too big which gives problems in the 1500 to 2000 rpm range (too rich, wants to stall). Secondly the corteco exhaust gaskets are too thin and are leaking already. Anyone tips for a good thicker set?
BigBlockk
Later.....
@Bigblokk: what would you suggest doing to solve this problem? We could tweak it some more, but perhaps other things will give a better result? Open to suggestions!
What's the total parts list and estimated output before and after?
Looks good for a few days' work
Doing part of the wrenching myself felt great indeed!We removed the engine because it makes working on it as well as painting it a lot easier.
The parts list:
- Edelbrock 60909 aluminum performer heads, 64cc Chamber, 170cc Intake Runner;
- Edelbrock 2701 EPS performer manifold, Dual Plane, Square Bore;
- Edelbrock 1411 performer carburator, 750 cfm;
- Edelbrock 9629 pushrods, .100 over;
- CompCam XE268H 12-242-2, camshaft and lifters, Hydraulic Flat Tappet, Advertised Duration 268/ 280, Lift .477/ .480;
- CompCam 1412-16, 1.52 Magnum Roller tip rockers;
- CompCam 2100, Timing chain and gear;
- Corteco engine gasket kit (32222-1CS)
I based my initial selection on the ChevyHighPerformance articles 'The Goodwrench Quest'. But due to costs I had to abandon my 'vortec quest' and went for aluminum heads instead. Turned out shipping cast iron vortec heads to Europe would have been (way) more expensive than buying aluminum heads of the shelf. Crazy world ey?
Anyway, the before output I can be very exact about: 168,5 RWHP and 329,8 Nm RWTQ. There seem to be some differences in European and US horsepower and torque measuring, but I guess it's close enough?
Estimate after output would be around 250 RWHP, but I'll get back on that in a few weeks/months when I've revisited the dynojet.
Further information: '95 Goodwrench engine, 4 bolt main, cast aluminum pistons, ca. 8:1 compression, TH350 auto, stock rear gears (3.55:1).
BigBlockk
Later.....
Also the mechanic stopped by (2 hr drive!) and retuned timing and carb. Timing turned out to be 6 degrees off, which was easily corrected and carb was a little lean, so set that a tad richer. Advance timing is back at 8 degrees with about 28 degrees of mechanical and vacuum advance making a total of 36 degrees. Runs like a charm now
One small problem remains with the 1500 - 2000 rpm area where she sometimes hesitates, but then continues (before she'd stall). This now only occurs when slowly passing 2000 rpm. Normal and hard accelleration give no problems. This hesitation, as Bigblockk already noted, can probably only be resolved with a calibration kit.
However, for now I'm satisfied as she runs good. Now to make some miles, change oil and filter and then go to the chassis dyno. From there I'll decide how to move on as I'll have more exact info on how she's doing.
Here's how the Corteco gaskets compare to Mr.Gasket in thickness. Please note that the Corteco gaskets are great (still no leaks anywhere), but just too thin for my headers.
