Looking for help with MSD system
Old Mar 18, 2008 | 05:58 PM
mark werner's Avatar
mark werner
Default Looking for help with MSD system
Installed MSD in 72 vette 454. Car runs great as long as I have the vacuum advance plugged. but once I connect the vacuum and increase the rpms ever so slightly the engine starts poping and backfiring. Car is set at 8 degrees BTDC as specs call for. I have all advance coming in around 3000 - 3200 rpm. and have tried all different set ups from heavy springs to light springs from larger bushing to smaller bushing with the same results. I have even tried different vac cans but keep getting the same thing with no luck once vac is connected. Has anyone had this problem and if so what can be done to solve it. I contacted MSD but they were of little help. With the vac disconnected the plugs foul up very quickly. Any help would be much appreciated.
Mark
Old Mar 18, 2008 | 06:27 PM
JustinD's Avatar
JustinD
Mark
Did you ever time it before you put in the new dizzy? Just thinking the harmonic balancer may have slipped. Maybe with the vac advance connected you are getting to much advance and it is firing to soon.
Old Mar 18, 2008 | 06:48 PM
mark werner
yes,the timing was set at 8 degrees and running fine. Did put in new balancer. when I did this over haul thing. I had just dropped in another HEI (not MSD) dist that a friend had and it works fine w/ vac connected.
Old Mar 18, 2008 | 06:55 PM
JustinD's Avatar
JustinD
Is it just a msd billet distributor? Maybe the coil is not getting enough power or something. Although I may just be pissing in to the wind.
Old Mar 18, 2008 | 07:26 PM
mark werner
yes, Pro billet dist with MSD Blaster coil and MSD ignition control
Old Mar 18, 2008 | 07:34 PM
JustinD's Avatar
JustinD
Did you have the box hooked up when you tried the hei?
Old Jun 3, 2008 | 09:47 PM
DEMITRISTYLES's Avatar
DEMITRISTYLES
From: You Can't Buy Cool, No Friggin' Way - Mississauga Ontario
ttt
Old Jun 3, 2008 | 10:13 PM
jr188's Avatar
jr188
2nd Gear
try setting your timing back to about 4btdc, then attach vacume to a ported vacume on carb. and readjust carb accordingly. I did this on a 350-350 and it worked out fine. for some reason when full vacume is attached, you get the popping through the carb and exhaust. I think the factory dist advances to quick and with the msd box, a lot more voltage is traveling through the system
To Looking for help with MSD system
