increasing compression ratio
Old Mar 19, 2008 | 10:58 PM
81doomesday's Avatar
81doomesday
6th Gear
Default increasing compression ratio
4.00 bore
3.48 stroke
12cc dished piston
.25 below deck
.018 compressed steel shim gasket 67cc
67cc head chamber
=9.16:1
Can I use a different gasket to increase the comp. ratio?
Old Mar 19, 2008 | 11:26 PM
1981Z06Vette's Avatar
1981Z06Vette
I doubt you'll find a thinner head gasket...you could mill the heads, though.
Old Mar 19, 2008 | 11:28 PM
Fubar569's Avatar
Fubar569
zero deck those slugs...compression will get interesting with 67cc heads and a gasket that thin
Old Mar 19, 2008 | 11:51 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Assuming you meant .025" in the hole, you don't have much, if any room to reduce quench below that very desirable .043" you're at now. Simplest method to increase your CR would be milling your heads.
To increasing compression ratio
