Billet mains
Old Mar 22, 2008 | 09:50 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Billet mains
Most companies really only sell the middle 3 mains.
Is there any real value in investing in the front and rear mains as well?
(7000 rpm 383)
Old Mar 22, 2008 | 01:56 PM
Little Mouse's Avatar
Little Mouse
(7000 rpm 383)
center three would be plenty.
Old Mar 22, 2008 | 02:50 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Front and rear only load 1/2 as much as the centers.
Old Mar 22, 2008 | 04:19 PM
Guru_4_hire
Cruise-In V Veteran
Thought as much.
Thanx.
Old Mar 22, 2008 | 05:06 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Old Mar 22, 2008 | 08:55 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
My new Motown block ( for my 427ci ) has all five caps four bolt and billet steel. The center three caps area also splayed.
Needless to say it will handle some power and probably more than I need right now. I am thinking about what I might need in the future The only downside id finding a pan that fits. Most pan will hit the cap on the front
Old Mar 22, 2008 | 09:17 PM
Guru_4_hire
Cruise-In V Veteran
The Katech 500ci Gen 4 small block sounds like fun. That will definitely do the trick.....
Of course the 6 bolt mains and cross bolts, the billet mains are sort of extra.
I really wish I had started a Gen 3/4 motor, instead of this 383.
Old Mar 22, 2008 | 10:09 PM
MotorHead's Avatar
MotorHead
There is something else about billet mains. Because they are made of different metal than the block they ( the block and the billet caps ) expand with heat differently, supposedly it is harder on the main bearings
I can make a 454ci out of mine eventually
Old Mar 23, 2008 | 06:36 PM
Stroker-427's Avatar
Stroker-427
Some people prefer nodular iron caps...... due to the different thermal expansion !
For my feeling you should aligne-bore the mains with the block heated!
To Billet mains
