Replacing sunvisors on 73 - HELP!
Old Mar 23, 2008 | 12:33 PM
C7GrandSport's Avatar
C7GrandSport
Default Replacing sunvisors on 73 - HELP!
Please tell me what I need to know regarding installing new sunvisors on my 73. Need to replace with correct madrid grain I have on order from Ecklers. Heard it can be a PITA!
Old Mar 23, 2008 | 12:37 PM
chris75stingray's Avatar
chris75stingray
should be pretty straight forward. unscrew old ,put in new.
Old Mar 23, 2008 | 12:57 PM
C7GrandSport
Heard issues about them drooping, not being even, etc. Anyone with experience in doing this?
Old Mar 23, 2008 | 01:09 PM
Shift_Happens's Avatar
Shift_Happens
Old Mar 23, 2008 | 01:27 PM
RMS73's Avatar
RMS73
The drooping is cause by the internal support in the sunvisor bending/breaking. For me this was because the sunvisor and/or support rods had considerable rust that would not allow the sunvisor to pivot easily. If you kept the sunvisor interior pivot areas and the rods free of rust, ie lightly lubricated, you'll have no problem.
Roger
Make certain you keep the old sunvisors. The driver's side should have the starting instruction label which I understand is not made as a repo in the correct material. You may want to installed the label on the new sunvisor for show/judging purposes.
Old Mar 23, 2008 | 07:00 PM
C7GrandSport
Roger
Ordered a repro label which I was told was woven fiberglass like original. We'll see when it arrives.
Old Mar 23, 2008 | 11:13 PM
RMS73's Avatar
RMS73
Let me/us know if the repo label is correct.
Roger
To Replacing sunvisors on 73 - HELP!
