U joint strap removal
Old Mar 24, 2008 | 09:33 PM
superdad60's Avatar
superdad60
Default U joint strap removal
Might be a kook question.
First time u joint are coming off
Car is up, wheels and drums are off and rear suspension is out
What is the best way to keep the drive line from turning so I can break free the u joint straps?
Does it matter to do driveshaft first or half shafts?
Don't want to hurt anything by doing it wrong.
I did a search and read before asking...
thanks
C3 with 4:11 rear and it seems like never been done before
Old Mar 24, 2008 | 09:40 PM
J Koehler's Avatar
J Koehler
Is the rear still in the car? Is the drive shaft still attached to the trans?
Old Mar 24, 2008 | 10:00 PM
72LS1Vette's Avatar
72LS1Vette
If you have an impact wrench you should be able to loosen everything without spinning the shafts much. The halfshafts are designed to withstans hundreds of lb-ft of torque so you could just jam a bar in somewhere to wedge the shafts from moving.
Rick B.
Old Mar 24, 2008 | 10:15 PM
superdad60's Avatar
superdad60
I'll go with the impact technique and see if she pops
I was using a breaker bar and too slow of a rotation definately
Yep dif and drive shaft are still in the car...
Old Mar 24, 2008 | 10:21 PM
72LS1Vette's Avatar
72LS1Vette
Dose everything with PB Blaster daily for at least a few days before trying to loosen nuts or bolts. I have found that PB will free up anything that isn't rust-welded together, but it may take a few days.
Rick B.
To U joint strap removal
