Brake Caliper Question
Old Mar 25, 2008 | 09:39 PM
brian76's Avatar
brian76
Default Brake Caliper Question
As I suspected, the piston seals are shot in my calipers. I need to take them apart, but have never done it before. How do I remove the pistons from their bores? If I can get them out I'll hone it. They sell some O ring kits that are said to be better than the standard lip seal kits- is this true? Thanks all
Old Mar 25, 2008 | 11:32 PM
Scott Marzahl's Avatar
Scott Marzahl
Remove the outer seal and you should be able to just pull out the piston. Yes, the O ring kits are nice assuming your bores are not pitted.
