Which ignition kit?
1) Yours was worn out. There's justification right there to spend money
2) Would have cost more to fix than replace, there's more justification.
3) You wanted features that the OEM unit does not have.
4) Your engine was modified to a degree where the OEM part cannot keep up.
None of the above reasons are Bubba-ish. You are the exception to the rule having done your research. I would have done the same as you.
Bubba needs to fix problems that don't exist based on marketing hype that convinces them that there's available horsies under the hood that can be unleashed for only $29.95 with FREE SHIPPING if you order now. BUT WAIT- there's MORE! We'll include absolutely free of charge a FRREEE life time supply of muffler bearing polish- and all you pay is shipping and handling............
Why not install the engine run the stock hei unit and see if it works good enough and make your own judgement from there?
Higher compression does not need a wider gap.
Stock HEI was designed for (and can easily fire) a .060 gap, never mind .045
Wider gap does not let you run a cooler plug.
We may have a winner here!
Having said that, alot of people do run them due to the current hype, looks, and mis-information. Their stuff is good, but overkill for most engines (kind of like putting a huge Holley on a stock motor type of thing
). I personally am running the GM HEI distributor that came with my ZZ4 with a MSD coil, low resistance bushing, cap, rotor and ignition module, along with a CRANE adjustable vacuum advance kit. Reasons are:- Coil - needed one any ways and I run over 6000 rpm
- Low resistance bushing - the coil melted the GM high resistance one into the cap
- Cap & Rotor - needed new ones due to age
- Ignition module - wanted an RPM limiter without using a seperate box
- Crane advance kit- able to tailor the advance curve to my taste
I don't have before & after times for proof, but I can assure you the engine runs hands down better than it did with the stock HEI. Mostly due to adjusting the advance curve. The other stuff is there so I know that the ignition is not limiting my engine. Ignition mods can only gain HP when they are the limiting factor (that's pretty much true with any engine component .... air filters, manifold, carb's, ignition, etc.).
None of the above reasons are Bubba-ish. You are the exception to the rule having done your research. I would have done the same as you.............
Well said.
That's a fairly logical and cost effective path. You had a problem that could not easily be solved, and purchased some reputable equipment which cured the apparent problem.
To be 100% Bubba, you must have no real cause to suspect or replace a given part, other than the guy on Speedvision said it was all good (followed by a commercial from the same company) and/or there's a full page colour ad in the latest Jeg's catalogue.
Once you've replaced the part you must now claim that it makes the car run much better, but not be in a position to back it up with any real facts like quarter mile times, fuel economy numbers, etc,etc. Instead, you refer everyone who inquires to the marketing literature that back up your claims.
Finally, you must become indignant when people point out that you may have wasted your money on foolish upgrades.
Bonus points can be awarded for adopting the attitude that anything that GM put on a car was junk because we all know they're idiots and that the bean counters were actually in charge.
So, having said that, thanks for playing the internet version of 'Am I Bubba' but I'm afrad that we can't declare you the winner.
The technology in the points distributor is 60 plus years old. The stock HEI is 30 plus year old technology. GM went to HEI for a reason. As you said the bean counters were in charge. developing a new distributor cost big $ and retooling. GM didn't make the change for no reason. The HEI was better. Now it is crank trigger that has replaced HEI. That change didn't come cheap or easy either and cost GM big bucks but is a better more efficient system. It is similar to roller cams. The flat tappets work fine and run good but the new technology runs better, produce more power and are more efficient, or fuel injection replacing carburators for the same reason. My mileage, idle quality and throttle response were noticably improved with the MSD over the stock unit even after the rebuild, recurve and complete tune up. Also my spark plugs were only good for a short period of time with the points distributor. With the MSD the plugs still looked almost new after 10,000 hard miles. I know it is hard to change some peoples outlook on this, hey I am old school too, I have a tripower, 50 year old technology. I know some of the new 4 bbl setups will produce more power but..............................
All that's needed from the supplier's point of view is to market a solution to a problem that doesn't exist.
1) lean mixtures in the early smog engines were very difficult to light. A larger spark gap with a more powerful spark behind it was a required.
2) engines were required to remain 'in tune' for extended periods without maintenance to meet the new smog regulations. As you have found, points wear causing dwell and timing to change. Electronic systems which eliminate mechanical points achieved the goal.
Neither reason has ANYTHING to do with enhancing performance.
BTW- When I said, the 'bean counters were in charge', I was making fun of Bubba. That's one of his favourite reasons for blaming GM.
Ok...............
I am bubba.....
I knew it!
Edit: If I had a totally stock NCRS judged car I would probably go with Pertronics or leave it stock. If I was running a slightly modified car on a budget I would go Pertronics or HEI if I had room. If I am running a highly modified car with no reason to stay stock using Nitrous, Supercharger or turbo (my car) I would go MSD or other aftermarket ignition with the available plug and play components available to adjust your ignition and timing to work with the modifications. The built in rev limiter is a real nice feature too!
Pertronixs does sell upgrades for points units and they also sell complete distributors. MSD also sells an upgrade kit which is exactly the same as the pertronix module and coil with the addition of a rev limiter built into the module but costs almost twice the amount.
I have been talking about upgrading parts on the stock HEI distributor and nothing else.
Other people have bought points style distributors into this tread for no good reason or purchasing a whole new distributor.
The original question was should I use my stock HEI distributor with a new 383.
I stated my opinion in my last post. He also asked about future upgrades and at a higher level of modification your needs change, also addressed in last post.
BTW- my car is not anywhere near stock, nor is it an NCRS flight car. It is reasonably heavily modified and has turned a few heads on the street with it's performance. All the components were chosen without benefit of a Jegs catalogue or watching endless hours of Speedvision.
Horsepower numbers for 1974:
L48 195
L82 250
for 1975:
L48 165
L82 205
The addition of HEI played no part in those numbers being what they are, BTW.
The point of this long dragged out saga is that if the stock system (points or HEI) is doing an adequate job of lighting the fire, then an aftermarket system will not gain anything. I think Lars did a comparison that demonstrated this.
