If you have stock rocker arms or roller tip style you should be able to use the baffles. They prevent oil mist and oil splash from getting out of the engine. This is a good thing.
If you have aluminum full roller rockers you might have clearance issues with the stock style baffles. I am sure someone with that problem will back me up here or say otherwise.
From: San Diego - Deep Within The State of CONFUSION!
-Mark.
I used a double-thickness gasket & my Crane Roller Rockers work fine.
