Dual Quad guys....... please step forward !
Old Mar 26, 2008 | 09:48 PM
454Can-Am's Avatar
454Can-Am
Default Dual Quad guys....... please step forward !
Okay guys................ need some help on my dual quad set-up for the '76 I'm working on !
I've got a couple of (1406) 600 cfm edelbrock carbs that I need to de-jet and reduce to 500 cfm. I need to at least find a starting point for the jets and needles.
I've got the low rise dual quad edelbrock intake manifold atop a 350.
350 bored .030 over
aluminum (small runner) racing heads
Crane energizer 278 cam
200-4R overdrive
Any input will be greatly appreciated........... Thanx guys. Rick
Old Mar 26, 2008 | 11:14 PM
gkull's Avatar
gkull
CFM is a function of the throttle bore size.
Vac secondary carbs can be made to run
Old Mar 26, 2008 | 11:53 PM
454Can-Am's Avatar
454Can-Am
Yeah........... I do know that I can't change the size of the cfm.s
I'm just trying to reduce the size of the jets and needles to what the 500 cfm carbs are, so I don't overload the engine. I guess I should have been a little clearer ! Thanx, Rick
Old Mar 27, 2008 | 12:36 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
It doesn't work that way. Carbs are airflow dependent. If they are right on a 454....you can put them on a 283 and be pretty darn close on jetting. The correct jetting will give a good A/F ration for THAT carb regardless of what it's bolted to.
Not to say you can't lean it some if needed..but the jetting for a 500 won't work correctly in the 600 most likely.
JIM
Old Mar 27, 2008 | 08:20 AM
The Money Pit's Avatar
The Money Pit
Rick,
I did a quick search on the Summit Racing site,looked up an Edelbrock 1404 carb (500cfm) and looked at the "manual.pdf". I think that is what you're looking for.
Post some shots of the CanAm. Been a while since I've seen it.
To Dual Quad guys....... please step forward !
