MAP sensor error
Old Mar 27, 2008 | 07:00 PM
ledzep4788's Avatar
ledzep4788
8th Gear
Default MAP sensor error
A friend of mine has a 82' with the crossfire injection and he can't get it to run. It threw a code saying MAP sensor error so he replaced the MAP sensor and still it doesn't run and the same code comes up. Any ideas?
Old Mar 27, 2008 | 07:17 PM
Greg73convertible's Avatar
Greg73convertible
Just a thought. my 88 kept showing a MAF code. replaced several sensors, took to shops 3 , last shop and $2500 later a bad o2 sensor (It showed good on codes) was causing a eh er... bla bla bla.... I know they are different Thought it might be the same problem..
Old Mar 27, 2008 | 07:29 PM
Toms82's Avatar
Toms82
Hi,
MAP sensors throw code 33 (electrical fault) or 34 (vacuum fault). I don't think the MAP could cause a no start condition. There are a number of things that can cause the motor to not start. Is fuel spraying from the injectors?, if no, fuel pump might be bad. The crossfire will not start if no oil pressure is detected, is there enought oil in the motor? is the oil pressure sensor working? The anti theft system will lock out the starter if it's in alarm mode. Are you getting spark? The ECM (computer) might be fried. You didn't mention if the motor cranks or when it was last running, but these are a few basic areas that could cause the motor to not start.
Good luck,
Tom
Old Mar 27, 2008 | 07:31 PM
Dirtbuster1's Avatar
Dirtbuster1
Changing the Map sensor will not make the code go away. You have to disconnect the battery, or remove the fuse to the ECM to clear the memory. I don't think the Map sensor will keep it from running. A vacuum leak will also make it pull that code.
Do you have fire at the plugs. Are the injectors spraying fuel when you turn the key on? Need more info!
To MAP sensor error
