Fuel pump for a 76 vette
Old Mar 30, 2008 | 07:16 PM
NUCCI's Avatar
NUCCI
Default Fuel pump for a 76 vette
Would any 350 fuel pump fit my system?Or do I need the oem stock one?I have a new 350 fuel pump that has a single fuel inlet line.On the 76 it has the one that has the main fuel inlet and a smaller line that goes back to the tank.I just bought this vette for a summer project and need to get running.I need to drive it through back yard to the end of the driveway so I can get it towed home.The back yard is still wet and damp.Thanks.
Old Mar 31, 2008 | 12:24 PM
BKbroiler's Avatar
BKbroiler
An aftermarket mech pump without the return line will work - as long as its pressure is not too high where you would need a regulator. You would be better off using an original type pump with the return line as a long term solution.
Old Mar 31, 2008 | 02:47 PM
lars's Avatar
lars
A stock AC/Delco pump correct for your car with the return line has a lot of benefit - the return line systems really do work well. Those of us with cars that had no return line from the factory go to a lot of trouble to fabricate and install return line systems, so don't disable your return when all you have to do is install the right pump.
Lars
To Fuel pump for a 76 vette
