I have something draining the battery on my 75 vette. No interior lights are on-all functioning fine, and the key switch is turned off but if I leave my battery connected for as little as 3 days I will have a dead battery. I am not driving the car yet but work on it 3-4 time a week and crank it at least twice a week. Alternator is brand new and working fine, battery is brand new-the third one I have installed because of this situation. How do I go about troubleshooting to solve this problem. Any help will be greatly appreciated.
Disconnect the battery lead and run an ammeter in between the battery and the battery lead. If you have a draw it will register amperage. Leave it connected and pull individual fuses, checking ammeter as you pull fuses. When the amperage goes to 0 you have found the circuit with the draw. Troubleshoot that circuit.
If all fuses are removed aand you still show a draw, then you have an issue with cables/wiring that are not fused.
Another thought - take the bulb completely out of the center glove box. And check the battery connections with a flashlite - the connections may seem tight because of heavy cables but perhaps not making full contact.
I had the same problem on my 76. First I installed a battery kill switch so I could save my battery. After many hrs tracking this problem ,it was the original horn for the alarm.If you have the same ,86 the horn. Might be your problem too.
theres soo many things it could be. alarm, clock, lights, etc etc. some get lucky and find it, some don't. I have been searching for years on mine but couldn't find it even after eliminating all the known suspects. I finally installed a master switch and couldn't be happier. even ran a jumper wire to the radio to save my presets anyway thats my suggestion. jegs has a great master toggle switch for $20 and its much more practical than the screw together types.
if i have a battery drain i wouldn't know because i put a switch in my ground wire and i cut power from the battery off when vette is parked for extended periods and this includes overnight.I bought this battery in 1999 and it sat from November last year til last week about March 24th,as with every other year prior, flipped the switch and it turned over strong for about 7 seconds til the car fired up.i see alot of posts concerning this so i think this was a good investment,also a thief would have to reroute my wiring before he stold my car.
