Leaf spring -- replace or recondition?
Old Apr 2, 2008 | 11:53 PM
rihwoods's Avatar
rihwoods
Originally Posted by damlie
How much for the new one?
$299.00....it is 1 1/2" shorter overall for more tire clearance,and approx 50# stiffer than the stock FE7....
Old Apr 2, 2008 | 11:58 PM
ajkogut's Avatar
ajkogut
So you're saying i should order it from vbp and then give it to Chuck to install? He does good work and all, but don't you think that this is an install that I could handle on my own with a lift, some new bushings, and a few wrenches or am I way off on this? (I've never done this before)
Just judging from what you said here, you can handle it. Its a pretty simple install. In fact, see the link below...it takes you through it.
http://www.corvettefaq.com/c3/RearMonoLeaf.doc
One thing to be aware of is any change in ride height that might occur with the new spring. You may need to pick up longer bolts for the end links...any vendor should be able to help when you order a spring.
Old Apr 3, 2008 | 05:07 PM
damlie's Avatar
damlie
Perfect! I hadn't seen those two tech papers. Thanks y'all.
Old Jun 30, 2008 | 07:33 PM
damlie's Avatar
damlie
So three months after starting this thread, my new composite monospring is now installed. A buddy of mine helped me out and we got it all done in about 3 hours (not bad for 2 knuckleheads). Thanks for all the advice and special thanks to Rick for the Duntov recommendation!
Here's a few pics taken while working. I'll try to put one up of the finished project soon.
Next project: change front/rear shocks.
