Leaf spring -- replace or recondition?
Old Mar 31, 2008 | 03:18 PM
damlie's Avatar
damlie
Default Leaf spring -- replace or recondition?
My original rear leaf spring on the '79 is starting to "fan" a bit and has some surface rust. I had a mechanic tell me that I needed a new one. But most of the people I talk to (who know what they're talking about) are telling me that I can recondition it myself (ie: take a hammer and pound the sheets back into alignment, sand it down a bit, then wrap it with a new fitting and put it back in).
Without seeing a picture of it, what do you guys think?
Does anyone have any pics of doing this themselves or any stories to share?
Should I rust-coat it after I sand it?
Old Mar 31, 2008 | 04:50 PM
damlie's Avatar
damlie
anyone have any experience w/ this?
Old Mar 31, 2008 | 04:56 PM
Durango_Boy's Avatar
Durango_Boy
Replace it. The metal leaves wear out and lose their 'spring' no matter how much you sand or pound with a hammer. It's still a three decade old spring.
Old Mar 31, 2008 | 05:03 PM
stinger12's Avatar
stinger12
I have a stock leaf spring that I can sell you. Its from my 76 vette. The spring may have been replaced with one from a 79 vette because someone replaced the diff cover with a stock 1979 one.
I just noticed you're all the way in honolulu, so shipping would be a killer from Canada.
Old Mar 31, 2008 | 05:04 PM
damlie's Avatar
damlie
Know where I can order one for a decent price?
Old Mar 31, 2008 | 05:06 PM
damlie's Avatar
damlie
Yeah shipping would be plenty. Plus if I'm going to replace it I might as well get a new spring instead of just replacing it with another old one (even if it is in better condition).
Old Mar 31, 2008 | 05:22 PM
mikep3's Avatar
mikep3
Default Rear Spring
My 78 rear steel spring was nosy, I lube it but no change. Took it apart, sanded, painted and installed liners from a Spring Shop(truck repair place). It wooked prefect, but it is 30 years old and now I planning on a plastic replacement.
Old Mar 31, 2008 | 05:59 PM
BB68Vett's Avatar
BB68Vett
I believe you can have the rear spring re-arched at a driveline shop. I have no personal experience using a re-arched spring, but I know it is common practice. I would say though that pounding on the spring with a hammer as a do-it-yourself fix is probably a waste of time.
Old Mar 31, 2008 | 06:51 PM
r44s's Avatar
r44s
Got my new leaf spring for the 73 from Duntov Motors in TX. Helpful folks and fair price.
Old Mar 31, 2008 | 08:12 PM
damlie's Avatar
damlie
you mind if i ask how much?
Old Mar 31, 2008 | 08:24 PM
breathial's Avatar
breathial
Metal springs have "memory," residual stresses built into them. Over time, and cycling under load, those stresses to be "relieved," thus, the spring loses arch and spring-rate.
Get a new spring pack.
And avoid these shade-tree mechanics, who don't understand metallurgy.
Old Mar 31, 2008 | 08:51 PM
Greg73convertible's Avatar
Greg73convertible
1. order composite from vbp it is lightweight and shipping isn't too bad
2.chucks corvette off of ward street
Old Mar 31, 2008 | 09:30 PM
rihwoods's Avatar
rihwoods
I got a quote once for re-arching my 78 FE7 spring:$250.00 and if they did remove/install labor it was another $150.00...
I'm ordering a new one from Guldstrand...
Old Mar 31, 2008 | 09:39 PM
damlie's Avatar
damlie
So you're saying i should order it from vbp and then give it to Chuck to install? He does good work and all, but don't you think that this is an install that I could handle on my own with a lift, some new bushings, and a few wrenches or am I way off on this? (I've never done this before)
damlie's Avatar
damlie
How much for the new one?
Old Mar 31, 2008 | 10:01 PM
J Koehler's Avatar
J Koehler
I bought one from corvette america at the PA car show. It was 117and free shipping. I installed it and it made a big difference. The car sits a little higher.
Old Mar 31, 2008 | 10:21 PM
Fuelie74's Avatar
Fuelie74
Check a couple driveline shops around your area. They just might be the same price or cheaper for a new spring.
To Leaf spring -- replace or recondition?
Old Mar 31, 2008 | 10:32 PM
Glassbowtie77's Avatar
Glassbowtie77
If your handy with tools you can do the spring swap yourself it's relatively easy to do, just follow the instructions they give you with the new spring. I pulled my 7 leaf FE7 spring and put in a VB&P 360 lb monospring in about a hour.
Old Apr 2, 2008 | 08:11 PM
damlie's Avatar
damlie
How is the 360lb spring? I was thinking of going with a 340lb composite for the '79.
Also, is it true that you need different rear shocks for composite springs?
Old Apr 2, 2008 | 08:18 PM
Carl Granquist's Avatar
Carl Granquist
Default rear spring info
Have you looked at this yet?
https://www.corvetteforum.com/techti...D=75&TopicID=3
