Cleaning the floors.....
Old Mar 31, 2008 | 05:18 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Default Cleaning the floors.....
Anyone got any advice on how to get this crap off? Its left over from the old insulation. I have tried laquer thinner and it just makes a bigger mess. Its like the surface of an old tennis ball. I need to get it off so I can glue down my new sound and heat insulation!
Old Mar 31, 2008 | 05:26 PM
champs65's Avatar
champs65
Maybe sacrifice a few cheap wire brushes to get rid of the hair followed by goo-off??
Acetone seems to work good as well for loosening things up.
Old Mar 31, 2008 | 05:28 PM
blckslvr79's Avatar
blckslvr79
Electric clippers???
That must have been some darn good glue!
Old Mar 31, 2008 | 05:44 PM
Durango_Boy's Avatar
Durango_Boy
I don't know if it works best but I used a power drill, an angle grinder, and a die grinder all with wire wheels, to get the most of that glue and hair up off the floor.
Old Mar 31, 2008 | 05:48 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
I thought I had it in the picture, but you can barely see it at the bottom right of the top picture is a wire brush, three swipes and its clogged up. I tried a wire wheel on my high speed grinder and it choked up in about 20 seconds, just seems to spread it around instead of taking it off. I will try the acetone next.
Old Mar 31, 2008 | 06:55 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Bit out of the box, but could you carefully use a hand held torch to singe the bulk to get you down where the wire brush could remove the glue? Hopefully before you try the acetone
Old Mar 31, 2008 | 07:25 PM
Durango_Boy
That doesn't seem safe...I can imagine the hairs catching fire instead of singeing. Anyone else ever tried this? I'd be too scared to.
Old Mar 31, 2008 | 07:43 PM
78Vette-SA's Avatar
78Vette-SA
I tried a different approach which worked for me more than once. I heavily soak the leftover padding with 3m Adhesive or other remover. (I poored it into a spray bottle and just sprayed the daylights out of it) Ten I cover it with a sheet of plastic (garbage bags will do) to keep the air out and keeping it from evaporating right away and letting it soak real good.
Next day with a little work it ussually comes up without too much hassle. I will admit yours looks more like a Wookie but can't hurt to try a few different things.
Old Mar 31, 2008 | 08:25 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
An alternative would be using a heat gun to get the fuzz to a manageable level. Come on DB, where's your sense of adventure?
Old Mar 31, 2008 | 08:26 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
I just tried the heat gun and a bondo spreader. No go. May have to try the bikini wax method next!!!
Old Mar 31, 2008 | 08:36 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Originally Posted by L82shark
... No go. May have to try the bikini wax method next!!!
Be sure and post pics. NO NO, on second thought get that visual out of my head
Old Mar 31, 2008 | 08:38 PM
Durango_Boy
Old Mar 31, 2008 | 08:46 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Close (Pace Car color scheme), but no cigar.
Old Mar 31, 2008 | 08:53 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
besides its a chrome bumper, if it had been one of our rubber bumpers there would have been more black smoke and a ticket from the EPA.
To Cleaning the floors.....
