I've read a bunch of posts that say to put the shims back into the trailing arm equal on both sides. I'm getting ready to pull mine off to put new bushings in them and they have 3 shims one the inside and 1 shim on the outside. should I just put them back that way? I will be taking it for a alignment later.
I think what they meant was right inside should be the same as the left inside and the right outside should be the same as the right outside. I am sure if I am wrong that someone with correct me on this one.
If you know the T/A's are original from factory, I would set it up the same way. When I pulled my shims out I labeled the OEM shims drivers outside & driver inside and did the same for passangers side. My arms where set up pretty much in the center of the frame. I'm no expert. but I would think you want the T/A pretty much in the center.
Take your extra shims when you go for an alignment and tell them if the rear is off here are shims to make it right. As long as it's a quality shop they will set the rear accuratley. Some other shops may tell you it's fine and set the front alignmnet to the rear as is.
I was told if I put the same unmolested trailing arms in - say I just painted them, put the shims back in the exact locations. If the arms were rebuilt, changed or the bushings were changed, reinstall with an equal amount of shims on each trailing arm.
The trailing arm pocket hole was suppose to be a specific width allowing for an equal amount of shims on each side of the trailing arm. But - bubba would get in there and over torque the bolt collapsing the pocket. You may have to force some shims (prefer stainless) in one side but they should be tight. Once I figure out how many I need on each side, if necessary, I will install the thinner ones first then force a larger one in last.
I just finished replaceing my trailing arms and placed equal spacing on each side. The shims that were in there were rusted so badly that I could not detirmine how many I had in each side. I plan on taking the car to have it aligned as soon as it is on the road.
The toe will be off after you mess with the bushings, just install an equal number of shims to hold it in place to get the car to the alignment shop.
Be sure to us slotted shims versus shims with a hole. If you install shims with a hole the alignment shop will have to remove the bolt to do a shim change. Do you think they'll actualy do that?
My '68 came with holes in the shims, no slots. The stainless ones I ordered have a slot and a hole. What is the best way to install the new shims? Push the slotted end up to the T/A bolt and slide the cotter pin through the hole at the bottom of the T/A pocket, or should I slide the bolt through the hole end of the shim and leave slotted end pointing down to the T/A pocket? For installation purposes, it would seem easier to have the slotted end on the T/A bolt, but relying on a long cotter pin as the only way of securing or keeping the shims in place is worriesome. Any help is much appreciated.
Thanks.
The part that looks like a two pronged fork rests on the trailing arm bolt shank. Pack them in tight, then hand tighten the the bolt nice and tight to align the castle nuts with the cotter pin hole in the bolt.
Are you sure? The cotter pin that came with my shims is easlily 4 - 5" long and did not come packaged with the T/A bolts, which did have a new castle nuts and cotter pins. The AIM for my car shows the shims as having holes on both ends with no forks or slots and having a bolt go through the hole.
I just had my rear end (and front) aigned after installing new trailing arms. You should have seen the look of relief on the shop owners face when I showed him the new shiny shims with SLOTS instead of the old HOLES ONLY. They did an excellent job.
I'm positive. The older corvettes had holes on both ends. to get the car aligned or to change the shim stack, you had to remove the bolt and alter the shim size, then reinstall the bolt through the shim's holes. GM got smart and switched to a fork design instead. Now, all you had to do was loosen the trailing arm bolt, insert or alter the new shims, then retighten the bolt. The fork allows you to slip it over the trailing arm bolt as opposed to having to pull the bolt out of the pocket entirely. This is a much better design, and once the 4'' cotter pin is installed, those shims will never come out.
That's kind of what I thought. Like I mentioned earlier, my AIM shows the shims with holes on each end, with no fork or slot and the TA bolt going through the hole. I will most likely drill a small hole on each side of the pocket to slide the cotter pin through the hole in the shim as added insurance in case they should -- god forbid -- slide out. It makes total sense to make a design change like that to aid in any future alignment issues, but I find it odd that the T/A bolt will hold the shims in place like that and be secure. Thanks.
No matter what you do, when you remove the TAs, you'll need a new alignment after you put them back in. You can add shims back where they were to make it closer to correct - that way the trip to the alignment shop won't be as scary. If you don't do the alignment, tire wear will be excessive and handling may be impaired.
