3.08 Vs. 3.70....
Old Apr 1, 2008 | 07:12 AM
1Bad69's Avatar
1Bad69
Default 3.08 Vs. 3.70....
What would the RPM difference be between the two at 70MPH? Also how much of the seat of the pants feel would you lose with the 3.08's?
Old Apr 1, 2008 | 07:47 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Check this site to play with various ratios and other fun things.
http://wallaceracing.com/Calculators.htm
Unless you change trans gearing, expect a pretty big butt-o-meter difference.
JIM
Old Apr 1, 2008 | 08:00 AM
The Money Pit's Avatar
The Money Pit
I second the buttometer verification. I swapped mine from 3.08's to 3.70's back when I had little more than a warmed over 355,and it made a huge difference.
Old Apr 1, 2008 | 08:09 AM
GTR1999's Avatar
GTR1999
About 3-400 RPM crusing. 370 or 373 with 225-70x15 runs about 3400 rpm @65-70 mph.
If you're running an auto trans you might look into a 2400 stall TQ if you go to the 373's.
Old Apr 1, 2008 | 09:59 AM
rdm390's Avatar
rdm390
Cruising
Default 3.08 vs 3.70
Check this site
http://www.csgnetwork.com/rearendgearcalc.html
Old Apr 1, 2008 | 11:00 AM
auctionman256's Avatar
auctionman256
if you go with the 3.08 geta 4l60 tranny, when you take off it like 3.70 gears. plus you get the overdrive.
Old Apr 1, 2008 | 11:56 AM
sly vette's Avatar
sly vette
Same thing with a T5, which I am very happy with!
Old Apr 1, 2008 | 12:22 PM
BKbroiler's Avatar
BKbroiler
Half a second quicker 1/4 mile ET going from 3.08 to 3.73 for me.
Old Apr 1, 2008 | 02:00 PM
Dantana's Avatar
Dantana
I've got a 3.73 and a TH350 behind a ZZ4 that runs hot (literally) and I am between 3500 and 4000 for 70-80mph. Wheels are 17".
My butt-dyno loves the 3.73!
Old Apr 1, 2008 | 02:16 PM
ajkogut's Avatar
ajkogut
I don't have any of the math done (but others have provided simple online calculators you can use)...but a general comment from a 3.70 gear owner...the extra you get on the seat-of-the-pants meter is worth the extra revs at cruising speeds. To me, this gear is a pretty good compromise between too tall and too short.
I rarely take my car on the expressway right now (the suspension rebuild currently underway will change that, probably) but I do cruise at a steady 60 or 65 (on 2 lane highways) and the 3.70 feels just fine. The way I figure it, the sidepipes sound better at higher revs anyways, so the 3.70 keeps me in the sweet-sounding zone a lot more. If you're one that keeps track of fuel economy (which, I don't on this car...because honestly who cares? Its a hobby, I'm just happy to drive it when I can), you will definitely see a difference. For instance, as a DD, I certainly would go with a 3.08 or thereabout...maybe a 3.55.
Good luck. The calculators should help you choose a gear but I wanted to give you some experience, too.
Old Apr 1, 2008 | 03:21 PM
7T1vette's Avatar
7T1vette
If you are thinking of going FROM 3.73 TO 3.08 [for fuel economy and comfort at cruising speed], it will be a huge improvement. As mentioned, the car's acceleration will suffer....but, at $4 per gallon, the 'suffering' will either be in acceleration or your wallet.
Old Apr 1, 2008 | 03:33 PM
jim2527's Avatar
jim2527
For what it costs to make the switch it'll take years to recoupe the cost of the gear change (depending on mileage driven yearly).
Old Apr 1, 2008 | 04:08 PM
1Bad69's Avatar
1Bad69
thanks guys..
Old Apr 1, 2008 | 07:22 PM
7T1vette's Avatar
7T1vette
{If you drive much on the Interstate, 3000+ rpm gets old pretty quick}
Old Apr 1, 2008 | 10:33 PM
joewill's Avatar
joewill
I bought mine with 4.56 gears, One of my first big projects will be to put in 3.08's. Running 3700 RPM in the interstate for an extended time makes me fearful of wearing out a very valuable engine.. I can take it around town, but I sure don't want to take it out of state on a long cruise. What on earth was the previous owner thinking when he put in that ratio? I probably don't care about a butt-o-meter.. I just like to cruise!
Old Apr 1, 2008 | 10:51 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I have 4.56 and love them, but I seldom run any major freeways. I like cruisin back roads, I removed 3.55. For the highway you'll like 3.08.
Old Apr 2, 2008 | 07:42 PM
SpE3dF0x's Avatar
SpE3dF0x
With a 200r4 w/ 3.73's what would it be? I was condisering the swap..or would 3.50's be a better route?
To 3.08 Vs. 3.70....
Old Apr 2, 2008 | 07:46 PM
GTR1999's Avatar
GTR1999
most of the diff's I built for OD trannies are 373 ratios. Good all around ratio with a OD.
Old Apr 3, 2008 | 01:33 AM
stinger12's Avatar
stinger12
This is the same setup I'm going with. The overdrive tranny will really cut down on the RPM's created by the new 3.73 gears. The 3.73's will also give you kick in th butt acceleration too boot
Old Apr 3, 2008 | 03:49 AM
theandies's Avatar
theandies
I like my 3.36's with the Muncie M20. 2800 rpm at 70mph. Works for me. If I had a 5 speed I'd go with a 3.73. Had that combo in a Camaro and it worked great.
