68 core support vs radiator
Old Apr 1, 2008 | 07:25 AM
Ronaldo's Avatar
Ronaldo
Default 68 core support vs radiator
Hi
Anybody know if this radiator
http://www.ecklers.com/product.asp?p...2&dept_id=1255
fits this 68 smallblock 4 speed coresupport?
Old Apr 1, 2008 | 08:41 AM
Andy&Kelly's Avatar
Andy&Kelly
ya, thats a 68 sb rad with 4 speed w no air.
andy
Old Apr 1, 2008 | 11:36 AM
71rdster's Avatar
71rdster
That radiator is for a car w/ac. Does your car have AC? You did not say, and it's not in your profile.
Old Apr 1, 2008 | 12:42 PM
Ronaldo's Avatar
Ronaldo
My car does not have A/C. But the radiatorsupport is not from my car. I have bought it a while ago. Its still on the way to europe...
But that radiator can't be used with my support then? Is it the two mounts in the bottom/middle that is responsible for it does not fit?
Old Apr 1, 2008 | 03:01 PM
Andy&Kelly's Avatar
Andy&Kelly
that rad in the picture at ecklers has the two pins at the bottom, small block 4 speed with no air. If i remember right, all BB and small block with air use the saddle type bottom, both the pics has the pin type,
and yes my other car is a 68 lol
andy
Old Apr 2, 2008 | 04:07 AM
Ronaldo's Avatar
Ronaldo
Thanks for the info
then I should also be able to change out the bottom mounts to saddle type/U mounts (I think paragon has them) and use a dewitts 68 BB direct-fit radiator instead, right?
Old Apr 2, 2008 | 07:13 AM
Andy&Kelly's Avatar
Andy&Kelly
Yes, the rad cradle structure is the same (except for some more holes in the air one for the lines), only difference is the lower mounts, which can be switched
I was in the same situation a few months ago, i needed a support for my 68, I have a 327 4 spd, but wanted to upgrade, so i got a BB support, and will run that type of rad
andy
Originally Posted by Ronaldo
Thanks for the info
To 68 core support vs radiator
