motor oil
Old Apr 1, 2008 | 02:20 PM
Rick B.'s Avatar
Rick B.
Default motor oil
What brand and viscosity oil is recommended by GM for a 1971? Also the previous owner said he used straight 30 wt. Do you guys have any experience with switching viscosities? What's the best product to use to try and help a rear main seal leak?
Old Apr 1, 2008 | 03:13 PM
Jims79's Avatar
Jims79
Depends on the miles on the motor. 10w40 high mileage oil is fine, a stop leak could help the main but if the seal is shot then nothing is going to repair it . It maybe time to replace it. I run 20w50 and add a good oil additive like Lucas to help on starts after its been sitting for a while.
Old Apr 1, 2008 | 03:14 PM
7T1vette's Avatar
7T1vette
There is no 'oil' that will help you get the rear seal to stop leaking. There may be some [short-term] additives that are made to reduce gasket/seal leaks, but I wouldn't put them in my engine. If the leak is significant, just have it repaired (and put in a new Fel-pro oil pan gasket at the same time). A decent mechanic can replace the rear seal without doing any major disassembly of the engine.
Old Apr 1, 2008 | 08:06 PM
dmayhew's Avatar
dmayhew
I do not believe GM would have suggested a brand name of oil.
As for viscosity , that depends on the climate you drive in and the way you drive the car.
The 30w seemed to have worked for the previous owner
David
Old Apr 1, 2008 | 08:55 PM
auctionman256's Avatar
auctionman256
true
Old Apr 2, 2008 | 01:08 AM
thrilher's Avatar
thrilher
i would go with Shell 30wt.It comes in gallons and if not on the shelf they usually have it behind counter at most parts houses.if you don't see that weight, just ask.
Old Apr 3, 2008 | 11:20 AM
Steve20's Avatar
Steve20
Shell Rotella T 30wt good stuff inexpensive at AAP
Old Apr 3, 2008 | 12:40 PM
CodyB4C's Avatar
CodyB4C
3rd Gear
Anyone using synthetic oil?
Old Apr 3, 2008 | 04:21 PM
jerrylee's Avatar
jerrylee
Redline 10-30....Jerrylee///
Old Apr 4, 2008 | 07:59 PM
SpE3dF0x's Avatar
SpE3dF0x
Moblie 1 Full Synth 5/30
San Antonio?
To motor oil
