Extension for Deep Trans-pan on TH400
Old Apr 1, 2008 | 03:33 PM
1970-Bronze's Avatar
1970-Bronze
Default Extension for Deep Trans-pan on TH400
What do I need to use a deep pan on a TH400 with regards to filter?
Old Apr 1, 2008 | 03:42 PM
Durango_Boy's Avatar
Durango_Boy
Nothing. The filter would be the same. The pan just allows for more fluid which results in a cooler fluid temp.
Old Apr 1, 2008 | 04:09 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
the deep pan will come with a extension and longer bolt to lower the filter. I have a b&m deep pan and thats what it came with.
Old Apr 1, 2008 | 05:33 PM
Durango_Boy
The TH350 I had in my old red Vette had a deep sump transmission pan but no extensions or extra bolts. Is B&M the only group that does add them? The only reason to lower the filter would be if the fluid fill level were to change, and that would require a different dipstick. If the fluid fill level is unchanged then I don't see a reason why the filter would need to be lowered.
You got a picture of the extension and bolt?
Old Apr 1, 2008 | 05:43 PM
Silver00V6Camaro
i have a th400 in mine. It has a half inch thick flange where it bolts so i would guess thats why i have to have the extension. I dont know if b&m just has them or not. i do not have pics. the extension is not very long its about 1.5 to 2 inches long and the bolt is just a little longer that factory. my pan is not a cheap one either its the 120 dollar cast aluminum deep pan that adds 2 qrts.
Old Apr 1, 2008 | 05:52 PM
Silver00V6Camaro
heres a picture i found a jegs you can see the extension and the longer bolt for the filter.
Old Apr 1, 2008 | 06:00 PM
Durango_Boy
Interesting. I do not remember seeing one like that before.
Old Apr 1, 2008 | 07:45 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The original GM steel deep pans used on trucks used a longer extension and bolt. Gm has them.
JIM
Old Apr 1, 2008 | 11:19 PM
71rdster's Avatar
71rdster
Mine is the same
Old Apr 1, 2008 | 11:26 PM
1970-Bronze
JIM
Do you remember the year so I can check at the parts store?
Do you think a Trans shop would have it?
Unfortunately, I don't have the bolt or extension.
Old Apr 2, 2008 | 07:40 AM
427Hotrod's Avatar
427Hotrod
Anywhere back in the late 70's for sure. One ton dualies with T-400's usually had them. Did many of them back in the day.
Best bet is probably Chevy or GMC dealer. It's just a plastic extension tube and a bolt..so shouldn't cost much.
A local trans rebuild shop might have some laying around....but I'd probably just hit dealer to save time. Probably won't be in stock, but they could have it in a day or so.
JIM
Old Apr 2, 2008 | 08:19 AM
Durango_Boy
JIM
I stand corrected. I guess I just never saw one installed correctly.
To Extension for Deep Trans-pan on TH400
