engine miss
Old Apr 1, 2008 | 05:18 PM
painterman52's Avatar
painterman52
Default engine miss
What would cause it to miss at about 3500 rpm and higher when I get on it pretty good. The car idles fine and runs good when driven easy.
Old Apr 1, 2008 | 07:15 PM
MN80Vette's Avatar
MN80Vette
I had a similar problem early last year. It turned out to be a timing problem. What are your timing measurements? What springs do you have on your weights?
Old Apr 1, 2008 | 07:27 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Could also be plugs and/or their wires.
Old Apr 1, 2008 | 07:56 PM
7T1vette's Avatar
7T1vette
Problem with anything in the ignition system (coil, plug wires, rotor, cap, etc.....) or fuel starvation at higher rpm's.
Old Apr 1, 2008 | 08:14 PM
painterman52
Its probably timing. I never timed a car before. I bought a timing light and changed things and now its missing. You should have to pass a test before some tools are sold to you
Old Apr 1, 2008 | 11:36 PM
MN80Vette's Avatar
MN80Vette
Did you see the sticky thread on timing at the top of C3 Tech/Performance?
To engine miss
