Header bolt removal?
Old Apr 1, 2008 | 09:59 PM
FLYNRYN's Avatar
FLYNRYN
Default Header bolt removal?
I have a 1969 coupe with a 350. I recently replaced the gaskets on my original headers with copper replacements. Some of the bolts are coming a little loose (i did not use threadlock). I am wondering:
1. is threadlock OK to use here?
2. Is it OK to remove one bolt at a time to apply it?
Id like to avoid ruining my new gaskets. any help would be great
Old Apr 1, 2008 | 10:12 PM
Fuelie74's Avatar
Fuelie74
Try the stage 8 header bolts. They are a little pricey but they won't come loose.
http://www.jegs.com/p/Stage+8/749275/10002/-1/11539
Old Apr 1, 2008 | 10:15 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
This was a constant problem I had also, the stage 8 bolts solved the issue. Two years now never had one come loose.
Old Apr 1, 2008 | 10:24 PM
stev5ko's Avatar
stev5ko
I got some header bolts at I think Pep boys that have a wire that runs between each or two bolts. It keeps bolt from backing out. Works fine for me but I would suggest that before you install wire to lock down that you install bolts and run a few times to op temp and retighten and repeat two or three times. Then go back and install wire.
Old Apr 1, 2008 | 10:49 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Don't use thread locker on header bolts! If anything, anti-seize the threads to keep them from "welding" themselves in place over time.
Stage 8's should solve the loosening problem. Great product.
If you safety wire, make sure to orient it properly.
Old Apr 2, 2008 | 08:55 AM
wiseman79's Avatar
wiseman79
Not quite to the point, but may be worth sharing. I use socket head bolts, so I can tighten with an allen wrench or allen socket. It make tightening the bolts easier since the pipes often get in the way of a box end wrench and an open end wrench can round the head of hex bolts.
Old Apr 2, 2008 | 10:37 AM
FLYNRYN's Avatar
FLYNRYN
Default One header bolt atta time?
Great! I'll get some stage 8 bolts on the fly. do I need to remove the whole manifold or can I do one bolt at a time? Any risk of ruining my new copper gaskets?
Old Apr 2, 2008 | 12:19 PM
7T1vette's Avatar
7T1vette
I don't see why you couldn't change out one bolt at a time....the gasket should be fine (if it doesn't leak now). Question: Doesn't anyone make French lock tabs for the [stock] header bolts?
Old Apr 2, 2008 | 12:28 PM
S489's Avatar
S489
like this?
http://www.volvette.com/exh-manifold-bolt.html
Old Apr 2, 2008 | 03:52 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I bought some of those at Auto Zone. They seem like they'll work well.
Old Apr 2, 2008 | 04:28 PM
7T1vette's Avatar
7T1vette
Put one lock on two adjacent bolts; put anti-sieze on bolt threads; torque bolts to spec then to next flat that lines up with a lock-tab; bend lock-tab up and flat against the side of the bolt head. Bolts won't back out.
Old Apr 2, 2008 | 05:42 PM
alanbl's Avatar
alanbl
Why the hell didn't someone tell me about these guys before now?????
The recessed allen head inside the hex head is worth more than the price of admission.
Thanks, Fuelie!!!
Old Apr 2, 2008 | 07:09 PM
moosie982's Avatar
moosie982
Like Archie Bunker would say, whats the chinese got to do with it. But on a serious note, I've never had a problem with header bolts backing out probably because I would run the car till it was warmed up to operating temp. ( A short drive) then go over all the header bolts from the center two out for a week or two (religiously). I had a collection of cheap 7/16ths wrench's that I "custom bent" to access the bolts better. Peace,,,Moosie
To Header bolt removal?
