1981 choke
Old Apr 2, 2008 | 04:01 PM
dfog's Avatar
dfog
3rd Gear
Default 1981 choke
1981 corvette choke light on dash fast idle wont kick off & choke only opens about 1/4 inch
Old Apr 2, 2008 | 04:15 PM
pbcanney's Avatar
pbcanney
blue (often appears green) wire comes from drivers side near alternator.
Old Apr 2, 2008 | 04:21 PM
thrilher's Avatar
thrilher
i would unhook the choke until its repaired or tie it full open
Old Apr 2, 2008 | 05:47 PM
a1sensei's Avatar
a1sensei
Check that the wire mentioned above is connected and hot. If it is, you need to ask Lars (v8fastcars@msn.com) for his quadrajet choke paper. It will take you though step by step. I found my '81's choke pull off coil was spinning freely on it's shaft. Whatever the problem, it's easily fixable with Lar's paper. God bless, Sensei
Old Apr 3, 2008 | 10:44 AM
SIXFOOTER's Avatar
SIXFOOTER
If the light is on then something failed, check the choke fuse
To 1981 choke
