does anyone know where I can get new rubber "clamp"s that sandwich the spring to the diff? ready to put it back together and rubber looks like #$%^.Thanks
Tom
I'm not in the market for a spring right now, and I don't want to take this thread too far off-topic, but do they fit better than the TRW springs which are notorious for causing high rear ride heights?
Sorry for the late reply. I just found this thread again.
We have found no ride height issues with our hyperco springs. Every spring made is load cell tested for accuracy so the rate is always on point. With our soft rate spring, stock 6" spring bolts can be used. With the 330 & 360 you will need to use 8" bolts.
