Fuel tank assembly.
Old Apr 5, 2008 | 09:11 AM
c373's Avatar
c373
Default Fuel tank assembly.
Hi!
I bought a new 18 gal fuel tank to my car ( c3/73). I made the anti squeak pads of a 3mm thick rubber. I placed them under the tank and under the steel tapes.
I have now a problem with to bend the tapes so strongly, that the screw on the frame meet the threads in the tape. I can not put the tape in the appropiate hole i the rear part of the frame. There is a lack of about 5mm ( 1/5 inch).
Do you know any manner to pre - bend the tapes?
Is the rubber possibly too thick?
Old Apr 5, 2008 | 01:28 PM
GunPowder's Avatar
GunPowder
Originally Posted by c373
Hi!
Hi Marius,
to my knowledge (and that's the way I installed my tank) the anti squeak pads just go betwenn tank and frame. No pads between tape and tank. Did the straps properly hook up in the frame? This picture may help.
Dirk
Old Apr 5, 2008 | 02:19 PM
c373's Avatar
c373
Hi Dirk!
Thank you for the information. Yes the Straps are hooked up properly.
After times in the garage and trying out many " tools" i find the source of this problem. The transversal impressions for the strips in the new "direct fit" tank are too flat. This is the reason for the fitting problems.
Now i wil try to bend the strips without the rubber under them.
Old Apr 5, 2008 | 02:28 PM
A88FXRS's Avatar
A88FXRS
c3 vettes use pads under tank and straps
Old Apr 5, 2008 | 04:39 PM
PRNDL's Avatar
PRNDL
c373 - When I changed the tank on my 68, I bought new straps and they were too short. I went back to the vendor who assured me that those were the correct straps for a 68 gastank. I ended up re-using the straps that I took off the old tank. The replacement gastank was exactly like the old one - same dimensions, but the straps were shorter, which made them way too short. I find it interesting that you are having a similar problem. I cut up some old bicycle tire tubes as padding and glued them to the tank straps.
http://forums.corvetteforum.com/show...0&postcount=41
Old Apr 5, 2008 | 07:29 PM
c373's Avatar
c373
I`m using the old straps, sandblasted and painted. I like to reuse the old parts and I suspected fitting problems with some new ones.
The tank is taken out ( one more time), because of one more failure. The welded border is not bended round sufficiently and it was impossible to bend it mounted in place. To bend him wil give me some more milimeters + the border will not scratch the straps. I will use some thinner rubber.
Thank You for help!
Old Apr 6, 2008 | 01:07 PM
Alan 71's Avatar
Alan 71
Just for what it's worth, (nothing) , my 71 only had two felt strips below the tank and none under the 2 straps.
Regards,
Alan
To Fuel tank assembly.
