bogs down
Old Apr 6, 2008 | 05:24 PM
81cali's Avatar
81cali
Default bogs down
Here's the deal, my car hasn't been used for almost a year. Just the usual warm ups and that's it. Last weekend, I took it for a drive (100 miles R/T).
It was fine all the way except when I was driving back and on a hill, it started to bog down whenever I would gas it up. I followed a semi up the hill going 25mph. on level ground, I punched it and as if nothing ever happened.....what are your diagnosis?????
Old Apr 6, 2008 | 06:02 PM
81cali's Avatar
81cali
I was thinking that probably my carb's float might be sticking from not being used????
Old Apr 6, 2008 | 06:13 PM
bonehead2's Avatar
bonehead2
Could be. Check the choke operation as well. Make sure fuel is not dripping from the squirters. Floats will do that.Adjust float level and drive again. Good luck.
Old Apr 6, 2008 | 06:19 PM
81cali's Avatar
81cali
thanks, will do just that and see what happens. i also have a spare carb and will try to switch
Old Apr 6, 2008 | 07:13 PM
694speed350's Avatar
694speed350
also you might want to check the accelatior pump for proper operation.
Old Apr 6, 2008 | 07:23 PM
81cali's Avatar
81cali
why is it that on level ground, it works just fine and you can punch it all you want???
To bogs down
