Shifter Problem 73 Vette
Old Apr 6, 2008 | 08:26 PM
ABOB5's Avatar
ABOB5
Default Shifter Problem 73 Vette
I Have A 73 With A Stock 4 Speed The Shifter Hits The Counsel For Reverse First And Third. I Got Under The Car And It Seems Tight. Any Suggestions ? Thanks
Old Apr 6, 2008 | 09:00 PM
trw's Avatar
trw
You need to adjust the Shifter Support Arm that connects the shifter to the cross member.
In the photo you add washers (6) to set the shifter back.
Hope this helps.
Terry
Old Apr 6, 2008 | 09:05 PM
LYLE's Avatar
LYLE
I have fixed this problem if you or someone has had the dash-radio out they did not get the consol mounted far enough forward. It could be wires behind the radio holding everything to far to the rear. The bottom of the dash will move in and out about one inch.
Old Apr 7, 2008 | 04:43 PM
ABOB5's Avatar
ABOB5
I did have the dash-radio out I will check this first then if this doesn't work I will go under the car Thanks
Old Apr 7, 2008 | 04:52 PM
jim2527's Avatar
jim2527
The console is fixed to a bracket on the floor so theres not alot of wiggle room.
You may need to rebuild your shifter to take the slop out or you can switch over to the short throw setting on the linkage.
Old Apr 7, 2008 | 05:14 PM
theandies's Avatar
theandies
Look at number 6 in the picture out of the AIM posted above. That is what you need to do.
Old Apr 7, 2008 | 05:26 PM
LYLE's Avatar
LYLE
Many times the console is like a wet noodle from cracks and broken parts.
Old Apr 8, 2008 | 10:12 AM
theandies's Avatar
theandies
jim2 527 has something there too. Rebuild it and switch to short throw. I switched mine to short throw about two years ago and it makes a big difference in the feel of the stock shifter.
Old Apr 8, 2008 | 05:06 PM
ABOB5's Avatar
ABOB5
How do you switch it to a short throw ?
Old Apr 8, 2008 | 06:36 PM
LYLE's Avatar
LYLE
The arms have two holes and you switch to the other set. This may cause you to need to readjust the arms so you will need to make a tool to fit in the slot to line everthing up in netural.
Old Apr 8, 2008 | 07:32 PM
hwcoop's Avatar
hwcoop
It really does make a difference..not as much of a sloppy feeling
mine seemed to be ok without making any adjustments aside from changing position of the shifter rods
Old Apr 8, 2008 | 08:37 PM
69elky's Avatar
69elky
Have you checked the rig neutral position of the shifter? This will be your starting point.There is a notch before the levers on the shifter module where you lay/hold a driill bit or bolt that fits into the diameter of the semi hole not like a Hurst where you insert rig pin into the shifter.Check for proper neutral adjustment and then throws,going into each gear selected.Later Geno
Old Apr 8, 2008 | 10:25 PM
LYLE's Avatar
LYLE
Gm must have different shifters as mine uses a flat 5/8 wide sheet metal tool to line up the levers for netural adjustment on a 73.
Old Apr 8, 2008 | 10:57 PM
69elky's Avatar
69elky
Your right Lyle,I just improvised with what I had when doing mine for relationship .Tried to keep it simple.Later Geno
Old Apr 9, 2008 | 10:06 AM
theandies's Avatar
theandies
I think you both might be right. My '71 has the flat style alignment fixture and I think GM may have gone to the round hole type alignment in later years of the stock 4-speed shifter. Anyway if you are checking your linkage or switching to short throw it's a good idea to use the alignment fixture just to get everything correct.
Old Apr 10, 2008 | 02:17 AM
69elky's Avatar
69elky
Amen brother,that was my intent.Later Geno
To Shifter Problem 73 Vette
