71 q-jet vacuum lines
Old Apr 6, 2008 | 09:26 PM
ndmick's Avatar
ndmick
Default 71 q-jet vacuum lines
I`m putting a q-jet for a 71 auto shift on and I`m not sure where the vacuum lines all go. It had a 7042220 carb on it and 2 of the lines are capped I would like to do it correct so I`m putting a 7041212 on it .If some one has pics that would even be better. but all help will be greatly appreciated .THANKS ALOT Ya`LL ARE GREAT HELP
Old Apr 6, 2008 | 10:13 PM
kansas123's Avatar
kansas123
On my 72, the line from the vapor canister to the pcv valve to the carburetor goes to the bottom front driver side vacuum port; the power brake booster goes toward the middle of the front of the carburetor and is clamped on; the small rubber line from the vapor canister goes directly to the passenger side front port; the passenger side carburetor port, towards the firewall, I used for the newly reinstalled vacuum advance canister hookup. This is probably clear as mud, and may not be correct, but someone else will probably correct me so we will both come out ahead....
Old Apr 7, 2008 | 10:38 AM
ndmick's Avatar
ndmick
I think 71-and 72 are different does anyone know if they are same or different?
Old Apr 7, 2008 | 05:30 PM
Alan 71's Avatar
Alan 71
I believe the pvc hoses are the same for 71-72. The spark control hoses are different because the 71 has a CEC solenoid on the driver's side of the carb, while the 72 had a TCS solenoid on the passenger's side of the carb. Dr. Rebuilds catalogue has some good drawings for how the hoses are routed. Dobbin's 68-72 Fact Book has good photos that show the routing, too.
Regards,
Alan
Old Apr 7, 2008 | 11:33 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here's a couple of pics of the 7041212 carb on my 71.
Old Apr 8, 2008 | 12:12 AM
Peterbuilt's Avatar
Peterbuilt
What did you use to get that carb so clean? PG.
Old Apr 8, 2008 | 05:52 PM
Alan 71's Avatar
Alan 71
gq82,
Great pictures of your engine. Love that small block!!!! Pictures really are worth a thousand words.
Regards,
Alan
PS: I notice that your thermostat housing doesn't have recesses in the base, my 71 doesn't either. I've always been led to believe that it should have the recesses.?!.?!.
Old Apr 8, 2008 | 06:28 PM
gq82's Avatar
gq82
Originally Posted by Alan 71
gq82,
Regards,
Alan
Thanks Alan...don't know what you mean by recesses in the thermostat base....
EDIT: Alan, I went back and checked my judging sheets from an NCRS regional show and the thermostat housing and fasteners were judged to be correct...no points deducted so I'm wondering who's telling you it's incorrect.
Jerry
Old Apr 9, 2008 | 05:25 PM
Alan 71's Avatar
Alan 71
gq82,
I'm looking at item #6 in section 21 on the judging sheets, and referring to page 84 in the 4th edition Tech Guide. I see the housing with and with-out the recesses around the bolt holes in the base. Does your housing have a part # you can see or is it covered up by the radiator hose? Some have the # on the flat horizontal area of the flange.
One last question, about when was your car built? Mine is #6589, a mid-January car.
Regards,
Alan
Old Apr 9, 2008 | 05:34 PM
gq82's Avatar
gq82
Alan, I see what your saying. No part number that I can see. Mine is 18101, late May build
To 71 q-jet vacuum lines
