Heater / a/c fan not working
Old Apr 7, 2008 | 08:14 PM
tbcbi's Avatar
tbcbi
Default Heater / a/c fan not working
I replaced the heater / a/c blower last fall on my '82 CE. Worked fine until last week. I took the car out and no blower on any setting. Are there any hiden tricks, fusable links,relays that I should be looking at ??? Thanks to everone...
Old Apr 7, 2008 | 08:34 PM
speedreed8's Avatar
speedreed8
i am no elec. expert, but here goes, first , check the 25a fuse in the fuse box under the dash marked AC. if its ok, then i would hook a test light to the blower motor power wire and try the switch on all settings.\
if no power to blower, then check power to blower relay, its under the hood mounted on side of ac box. heres a wiring diagram
http://www.corvetteforum.net/c3/tune.../index16.shtml
