master cylinder blues
Old Apr 7, 2008 | 08:48 PM
thunderlips's Avatar
thunderlips
Default master cylinder blues
So i buy a new master cylinder...after waiting [B]12[B] days for the freakin thing to arrive, i find that two of the brake boosters bolts are crooked. after aligning and fitting it in the car, i begin to bench bleed the master cylinder, only to find the brake fluid leeks out of the piston rod thing after pushing it to get the bubbles out. My old one didn't even do this and it was bad. I guess the booster would stop this from leaking out when bolted together....but should i return this peice of sh*t? is a little brake fluid supposed to drip out when i plunge that thing?
Old Apr 7, 2008 | 08:58 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Ewww, send it back!
Wher did you get it??
Keith
Old Apr 7, 2008 | 09:04 PM
OzzyTom's Avatar
OzzyTom
A couple of things to check, or you might repeat the problem again.
First of all, the plunger MUST move concentric to the bore of the cylinder... that is, when you press your pedal, the rod must move through a line parallel to the bore.
If it moves through an arc into the bore, then it creates uneven pressure on the seal and it can/will leak.
If the master cylinder mounting has been modified for clearance issues, then you may have an alignment issue.
Also, make sure the pedal travel is correct. Do NOT over extend the travel!
If you depress the piston further than specification, the O-ring seal is compromised and you will get a leak.
Old Apr 7, 2008 | 09:06 PM
thunderlips
Proir.....and i have to pay to ship the damn thing back! I found this out in a 14 minute conversation with indian costemer service.
Old Apr 7, 2008 | 09:08 PM
thunderlips
no the thing was leaking before i even plunged it for this first time, and at a constant drip rate.
To master cylinder blues
