Cooling Fan 79 l48
Old Apr 8, 2008 | 10:25 PM
Prominus's Avatar
Prominus
Default Cooling Fan 79 l48
Ok just bought a vet and the cooling fan is shaking......at higher rpms it shakes more and from the shaking it makes the belts make a nasty noise.........
now i checked out the fan and its a 6 blade...and I looked at the replacement and the original is supposed to be a 7 blade...also one of the blades was bent........not badly only to the point that the ( curve was more like ! could this be the source of the shaking??? when i jerk on the fan with the car off it doesnt budge
EDIT
http://cgi.ebay.com/ebaymotors/76-77...QQcmdZViewItem
thats the replacement i bought
Old Apr 8, 2008 | 10:33 PM
Durango_Boy's Avatar
Durango_Boy
Might be the bearings in the water pump going bad too.
Old Apr 8, 2008 | 10:35 PM
Prominus's Avatar
Prominus
Ok well hopefully the blade gets here soon.....if that doesnt work when i change it might need a new water pump
Old Apr 9, 2008 | 02:51 PM
rihwoods's Avatar
rihwoods
Do you have a clutch fan..??? If so,the clutch could be bad...it can damage your waterpump if so....
Old Apr 9, 2008 | 03:02 PM
redwingvette's Avatar
redwingvette
Change the clutch fan soon.
To Cooling Fan 79 l48
