Welders, step inside
Old Apr 9, 2008 | 01:26 PM
vettfixr's Avatar
vettfixr
Default Welders, step inside
I'm in the market for a small mig welder. I don't need something large because I mostly see myself using it on projects that would be less than 1/4 inch thick. The first job I'm going to use it on is to refurbish my seat frames that have some small cracks in the metal and hinges. After that who knows, maybe some exhaust or bracket work. I've looked at whats available and I'm pretty sure that a unit in the 125 to 140 amp range with gas would be ideal. I've looked at Miller, Lincoln, Hobart, and Clark. All have something within the range I'm looking for. However, I saw this unit at Sears and the package they offer for $399 is pretty attractive. It also looks as though it accepts Clark parts so I'm assuming its probably made by them. An equivalent unit from Clark or Hobart (Lincoln and Miller are both more costly than Clark or Hobart) would cost more. So, long story short, does anyone have any experience with Craftsman welders and does this look like a good deal?
http://www.sears.com/shc/s/p_10153_1...keyword=welder
Old Apr 9, 2008 | 01:35 PM
Black 82's Avatar
Black 82
You'll get a bunch of responses recommending a 220v welder. Good advice, but not practical for all of us.
Make sure whatever you get has infinite variable heat and feed. Many of the bargain machines have presets which I find impossible to dial in.
I've had a Lincoln SP125Plus for ten years and its been a great machine. Done many sheetmetal projects including aluminum and stainless. That being said, my next machine will be a 220v TIG.
Old Apr 9, 2008 | 01:41 PM
vettfixr's Avatar
vettfixr
Yeah, thats the problem. If you want to stay around $400 you get machines with presets. One of the nicest I've researched is the Miller Auto Set machines. You just dial in the thickness of the material and the machine does the rest. But you pay for that luxury, they run close to $800.
Old Apr 9, 2008 | 03:26 PM
jimbo1972's Avatar
jimbo1972
I have used alot of welders and am very impressed with the Hobart 110volt (cant remember the model right now) I got around christmas time. Great prices from Northern tools on them.
I have been useing it without gas (just the flux wire) and it lays a really nice bead, even on heavy guage metal
Jimbo
Old Apr 9, 2008 | 04:14 PM
dewcustom's Avatar
dewcustom
I have a craftsman and was not impressed the wire feed was inconsistant and the triger only stops and starts the wire feed the voltage was always on. you get what you pay for now i have a clark and am very pleased
Old Apr 9, 2008 | 04:32 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I have a Clarke 100EN (basically a 130EN that didn't come with the gas kit). It welds like a champ.
Old Apr 9, 2008 | 05:53 PM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
No experience with Clark or Hobart. I have a Millermatic. It's 120 V and works ok but I did run a 20 amp outlet to my garage. If I used it too much and had much other electric going on it would trip the breaker. Then I had to go through the house and down to the basement to reset
If your load center is in the garage it's pretty easy to make a 220 outlet to run a welder. The 120 makes it more convenient to move around though.
Stick to the big 3 if you want a decent welder - Miller, Lincoln Hobart.
Old Apr 9, 2008 | 05:54 PM
stinger12's Avatar
stinger12
I have the millermatic 175 - top of the line when it comes to quality. It runs on 220 volt and uses a mix 0f argon and co2...flux core welding sucks. YOU GET WHAT YOU PAY FOR WHEN IT COMES TO WELDERS!!!! Don't skimp on price. Save up the cash and buy a nice expensive one. 220 volts is much better than 110, but you need to hook up 220 volt in your garage or you wont be able to use it.
Old Apr 9, 2008 | 07:17 PM
bruced267's Avatar
bruced267
I do suggest a 230V welder. You also need to be concerend with the duty cycle, which amounts to how much weldind the machime can handle in so many minutes! The smaller the the cycle the less welding the machine can handle! I have a 230V Lincoln and its has given many years of service!! It owes me NOTHING and on its last leg and still works like champ if you know how to use it. I think the next one will be a Miller
Old Apr 9, 2008 | 08:01 PM
kyeakel's Avatar
kyeakel
I have a Lincoln 125, it has the presets and wire speed adjustment. It was a flux core, but I added the gas kit. The gas kit makes a world of difference in the quality of the weld. I've put together many small projects, welded new floorpans, patched my birdcage, welded up a patch on my frame and several other things. It seems to do pretty well for what I need. I also have a tig, but it takes me longer to setup and I always need a few practice welds to get the hang of it again. So, for most jobs the mig is my first choice.
Kipp
Old Apr 9, 2008 | 09:43 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
Dewcustom referred to something that is very important. Whatever you buy, make sure that the wire is not hot till you press the switch . There are times when you are trying to do some real fine work where you will want to literally place the wire on the spot, close your hood and then hit the trigger. If the wire is always hot you can not do that. I do not think any of the big three will have that problem.
Old Apr 9, 2008 | 10:11 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
I looked at the clarke and the only thing I didn't like was the drive rollers. I buought a 110v Hobart, works pretty dang good.
Keith
Old Apr 10, 2008 | 12:00 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Keith
I've never had a problem with my Clarke's rollers, though they do have a bit of a reputation for being finicky to adjust for proper feed.
Old Apr 10, 2008 | 12:06 AM
chvet73's Avatar
chvet73
That Sears is a Clark which is not one of the better machines out there. I have Linclon 135 and a Hobart 175. Both are good machines. In the 110 machines Home Depot has the 3200 Lincoln at a good price. My Lincoln does a great job up to it's capacity. Had a Cambel Hausfield 110v machine, no comparison to the Lincoln. I don't think the machines less than 135 amp are worth looking at. Any Lincoln, Miller or Hobart in that range are good. The 175-180 range machines are great but you do need 220v.
Old Apr 10, 2008 | 12:23 AM
stingr69's Avatar
stingr69
I bought a Craftsman. Needed parts while under warranty. NO SERVICE AT ALL. They would not accept an in-store return for this item. The gas valve was mechanical and leaked like a sieve. I sent it back UPS at my own expense and bought a Millermatic because the dealer is helpful and has the parts/gas etc in stock when I need them.
Miller is a much better machine by far. Makes my welding skills look much better that the Craftsman ever did.
Do not buy junk - if you can't get service or parts you will be screwed and out the money!
-Mark.
Old Apr 10, 2008 | 12:34 AM
Bud Merrill's Avatar
Bud Merrill
I have been a welder for 25 years, I had rejected any 110v machine untill one day I was in the local welding supply store and noticed they had a Hobart handler 140 (+/-$400) set up I asked to try it and WOW was I impressed, I have recomended this very machine to all that ask me this very question, as for craftsman....for $399 I would absolutely go for a more known name, good luck
Old Apr 10, 2008 | 09:33 AM
MonzaRedConvert's Avatar
MonzaRedConvert
I have the Lincoln Power Mig 140C. I also considered the Millermatic 140, but couldn't justify the additional price. I've found the Lincoln very easy to use for a beginning welder. It may be a bit beyond your budget though. I think I paid close to $600 for it, but then you need to consider the cost of a gas bottle, helmet, etc. It definitely adds up. I'm very happy with the welder though.
To Welders, step inside
Old Apr 10, 2008 | 12:13 PM
DaveD's Avatar
DaveD
If you stick with Lincoln or Miller you can't go wrong. Hobart runs a close second (IMHO). All 3 make good welders both in the 110V and 220V models. Hobart is just a slightly cheaper Miller (they are made by the same company).
My preference is a 220V unit in the 200A range (at this instant I happen to have both a Lincoln 200 powermig and a Miller 210) and you will never have to buy one again. Pay attention to duty cycle if you want to weld anything in the 1/4" range.A 10% duty cycle is really going to suck. The 200A welders probably (I can't remember) have a 60% duty cycle at the 1/4" range.
If you would ever think you could use a spoolgun then the Miller 212 (successor to the 210) is the way to go but its about $1450 delivered. Then the spoolgun is another $500.
Old Apr 10, 2008 | 01:11 PM
wro87's Avatar
wro87
Bought the same unit for my son to start on and I couldn't be happier. Bought it from Indiana welding (can find units from them on e-bay). He caught on to it after about an hour playing around and has reaaly stepped up to the plate while using only flex wire and now that I have shown him the difference with gas he is liking it better for the sheet metal on the chevelle. If you stay with one of the big names parts and service should not be a problem in the future ( can't say the same for krapsman ). Spend a little more and you will be happy, hell the local shop now has the lincoln 140c for $600 now and the miller just a little more.
Good Luck and have lots of fun wro87
Old Apr 10, 2008 | 03:34 PM
ctrain22's Avatar
ctrain22
I bought this Licoln mig with gas attachments for my son for Xmas...he loves it. can to both flux cre and gas welding.
