Key cylinder replacement 81 Corvette
Old Dec 12, 2001 | 04:55 PM
PAT68's Avatar
PAT68
Default Key cylinder replacement 81 Corvette
When putting a new key cylinder in the steerin colum, it won't hold.
Is there a special sequence to follow?
Please help.
PAT68
Old Dec 12, 2001 | 07:03 PM
Jim Shea's Avatar
Jim Shea
Default Re: Key cylinder replacement 81 Corvette (PAT68)
The lock cylinder in a 1981 steering column should be held in place by a separate screw. The screw is located in the column head and goes through a notch in the cylinder. Before 1979 the lock cylinder had a spring loaded steel
wedge that engaged a slot in the steering column head. Thiefs were able to use a slam puller to dislodge the lock cylinder and steal the car. In 1979 the steering column and lock cylinder were changed to a screw retained design.
Are you sure you have the correct lock cylinder? The GM part number for the correct screw retained cylinder is 7830380.
