Dart 23 degree heads
They also have the same runner size heads with raised intake runners
and spread exhaust. combustion chambers for standard location heads and raised runner range from 62cc to 67cc.
The raised runner, spread exhaust heads have valves as big as 2.125.
Anyway I sent off for there catalog to see if anything new was going on with dart. looks like they have been busy at dart.
they still have your heads they refer to them as PRO and the new heads as RACE. Damn I figured if you were a professional you were allready a racer.
they have other changes i'm not bothering to list. relocated spark plug location thicker walls for porting, I guess you can get out your drill make the 248 runner a 260. for that big 472 small block you built.
I guess Dart has realized that the big inch small block with 23 degree heads are getting real popular, smart move on their part
And then they have always had the Little Chief Heads if you want to get serious about building a small block
