Static
Old Apr 11, 2008 | 10:23 PM
glassman74's Avatar
glassman74
Default Static
Will static electricty in the fiberglass body have any effect
on paint job? If so, how do you get rid of it?
Thanks in advance. glassman74
Old Apr 11, 2008 | 10:31 PM
A88FXRS's Avatar
A88FXRS
never heard of this. what are you talking about.
Old Apr 12, 2008 | 03:45 PM
76projectstingray's Avatar
76projectstingray
a friend of mine who has painted a couple of corvettes before told me that you have to ground the body to get rid of the static before you paint. Don't know if its true?
Old Apr 12, 2008 | 04:38 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Never heard of this either.
Old Apr 12, 2008 | 08:16 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I've done several body off restorations and painted the cars off the frame. I've never had to ground the body to paint them.
Old Apr 13, 2008 | 11:13 AM
Durango_Boy's Avatar
Durango_Boy
Yes it's a good idea to ground a car before shooting. The air and moisture from the paint moving over the body panels generates static electricity. This is bad if you have a lot of dust and trash floating around as it'll get sucked onto the body if it floats too close.
The grounding is easy. Just use a chain, dropped over the rear spring, and maybe the front suspension so it lays on the floor and contacts the frame, engine, and body...assuming all your ground straps are installed and in good shape.
To Static
