Nitrous question?
Old Apr 12, 2008 | 01:32 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Nitrous question?
Made my last licensing run today and I ran a 100 shot on that run.. My last run with a 100 shot was 9.57 @ 143 mph.. Today, I only ran 9.97 @ 135.50 mph. The car seemed to run awfully rich and when I purged the nitrous, the nitrous cloud was very transparent.. It used to be very white on my last run about a month ago. I weighted the bottle before I put it into the car and it showed 18 lbs (bottle weights 14 lbs empty), so I thought that I was good to go.. The bottle has been sitting in the hot garage for a month or so, so I wonder if it affects the nitrous if it's sitting for a long time? Is it possible that 4 lbs of nitrous in the bottle wasn't enough? What could be the reason for the almost transparent nitrous cloud?
I did flow the nitrous system before the run and set the correct fuel pressure, so I doubt that the nitrous tune was off...
Any input is appreciated!
Old Apr 12, 2008 | 01:57 PM
red79vette454's Avatar
red79vette454
For best results top the bottle off before each outing.
Nitrous doesn't get old but when the bottle gets below half you will see a noticable drop in performance.
Using a 100 shot you will probably get 3-4 good runs on a full bottle. If you purge before and after each run maybe less.
When you get on a serious nitrous diet you will want to have several full bottles to start the day and change after every second pass.
Old Apr 12, 2008 | 02:41 PM
GrandSportC3
Thanks! I hope that this was the problem...
Old Apr 12, 2008 | 02:49 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Any idea what bottle pressure was?
As the amount of nitrous gets lower...there is a quicker drop off in pressure as you use more.
Years ago when I ran a lot of N20..it ws getting to be a PITA. I had 6 bottles I took with me to the track and had them all full before I left. Got pretty expensive and a lot of work. Should have bought my own refilling station.
I think you just ran out of juice!
Time to stock up!
We've been wondering where you've been.
JIM
Old Apr 12, 2008 | 02:59 PM
GrandSportC3
Time to stock up!
JIM
Bottle pressure was 900... No need to heat up the bottle. It was sunny and in the mid 80's today with high humidity and 15 mph headwind..
Only got to make my last licensing run today as I was on vacation in Hawaii..
Old Apr 13, 2008 | 01:01 AM
GrandSportC3
Here's the video of the run..
Old Apr 13, 2008 | 01:22 AM
stinger12's Avatar
stinger12
OMG, that car is sick!!!!! I am so jealous right now
Old Apr 13, 2008 | 10:36 AM
brngrhd's Avatar
brngrhd
very nice man
Old Apr 13, 2008 | 10:46 AM
78Vette-SA's Avatar
78Vette-SA
One other thing I have seen on cars with pressure over 1000psi and a new full load of N20 and blowing a clear cloud is the pickup tube in the bottle became unseated at the base of the head on the bottle. Probably not the case here but just something to consider. The bottle needs to be positioned correctly and the pickup tube functioning properly for everything to come together.
Just another .02!
Old Apr 13, 2008 | 12:12 PM
bojangies46's Avatar
bojangies46
Get a full bottle, nitrous is hard to tune when bottle is low, cant keep pressure regulated, still a nice run, motor sounds good, low pressure,car runs on rich side. ----JON
Old Apr 13, 2008 | 01:49 PM
GrandSportC3
The pressure was good, around 900 before and after the run.. The consistency of the nitrous seemed different.. In the video, you can't even see that I purged... it was so transparent..
Old Apr 14, 2008 | 10:15 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Time to stock up!
JIM
Got any of those old bottles lying around ?? I could use a few more !! I only have 4. I use over two lbs. of nitrous in 5 seconds.
Ollie, to do it right, as others have said you need have full bottles. Nitrous can be very consistent if you have a full bottle for every run. I swap my bottle out every run. As the volume of nitrous in the bottle goes down you can keep the pressure up with heat, but there is no nitrous in the bottle. No doubt with only 4 lbs of nitrous in the bottle there was a serious performance decline based on that alone.
Congrats on the license
Old Apr 15, 2008 | 07:24 AM
GrandSportC3
Thanks!! There's a Edelbrock bottle just like mine on Ebay for $75.. Seems like a good deal.. Will try to buy it!
Old Apr 15, 2008 | 10:14 AM
69 N.O.X. RATT
If you want a good deal on a nice blue powder coated bottle give Nitrous Supply a call........would match your paint perfectly.
Old Apr 15, 2008 | 10:39 AM
GrandSportC3
My vent tube wouldn't fit on any other brands's bottle. The Edelbrock system is the only system where the vent tube conects on top
To Nitrous question?
