A/C Hoses
Old Apr 13, 2008 | 09:12 AM
BobW75's Avatar
BobW75
Default A/C Hoses
Can you replace the metal fluid return line from the evaporator with a hose or does it need to be metal? I think it would be a lot easier to rplace, wouldn't have issues when tring to get it lined up.
Old Apr 13, 2008 | 09:28 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Stay with the metal pipe. (heat & pressure)
Old Apr 13, 2008 | 09:46 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The metal line should last the life of the car while hoses will wear out.
To A/C Hoses
