Gear vendors overdrive
Old Apr 13, 2008 | 11:24 AM
Belgian1979vette's Avatar
Belgian1979vette
Default Gear vendors overdrive
I just looked at their add on overdrive kits. Anyone ever use these ?
http://www.gearvendors.com/aghr4sm.html
Old Apr 13, 2008 | 11:30 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
no, but I want one. Have a new Autogear M22 with a Tom's 411. They will handle all the power you can throw at it. Posted about this before and they are the best OD option in my opinion.
Old Apr 13, 2008 | 11:34 AM
Belgian1979vette
Looks like it, but I would like to know how it performs, the way it works because I don't totally understand it.
Old Apr 13, 2008 | 11:45 AM
63mako's Avatar
63mako
It is an automatic, electronicaly controlled unit. Shifts instantly with a push of the button in any gear. No time lost on shift. I rode in a 50 Merc with one and it is slick.
Old Apr 13, 2008 | 11:59 AM
63mako's Avatar
63mako
Here is my closed post: http://forums.corvetteforum.com/show...t=gear+vendors
Old Apr 13, 2008 | 01:09 PM
Gordonm's Avatar
Gordonm
Bullit proof but $$$$
Old Apr 13, 2008 | 04:21 PM
Belgian1979vette
Does it fit a corvette transmission tunnel ? If not, what modifications are necessary.
Old Apr 13, 2008 | 04:46 PM
63mako's Avatar
63mako
I heard 2 small notches in the tunnel where the upper case bolts are needed in some applications. You also need a shorter driveshaft. I have checked on this upgrade with Gear Vendors. I really like this unit but it is very expensive. A Hurst T handle with a button is the trick setup. I have seen some posts on the TKO where they have vibration issues that are difficult or impossible to sort out and others work perfect from day 1. That is the only thing holding me back from selling my Autogear and going 5 speed. I would hate to spend $3500 on a 5 speed and have vibration issues I can't resolve. It would be pretty cool on the highway to shift to 4th standard to pass then upshift to O/D without pushing in the clutch and turning the 4.11 to a 3.20 to cruise.
Old Apr 13, 2008 | 06:22 PM
Belgian1979vette
I don't know, but to keep the gearspread of the close ratio muncie this would be a good choice. However the OD is a little on the small side, keeping me around 3000 at 75 with a 4.11 in the back.
Price sounds not that obnoxious when compared to the 3300 $ for a tko.
The fact that there are not many people who have done this conversion, makes me fear that it could be more difficult than just two dimples in the trans tunnel.
Old Apr 13, 2008 | 09:11 PM
a1sensei's Avatar
a1sensei
I looked at these and decided to go with a 700r4. Unless your engine puts out more power than a 700r4 can handle (which would be ALOT!), the Gear Vendors does not make sense. It is more expensive, has less overdrive, and to quote a forum member who installed one "They lie out of a dark smelly place when they say the installation is not difficult." God bless, Sensei
Old Apr 13, 2008 | 10:23 PM
63mako's Avatar
63mako
He has a manual trans and a 4.11. Wants to keep his manual. Same situation I am in. A TKO has too low of first gear for me. Means changing out the rear gear to get the most out of the TKO. Other options are Richmond 5 speed (expensive and not quite the ratios I want) or 6 speed (lots of mods), T56 (lots of mods)T5 (Lots of mods and weak if high HP). If you want to keep the 4.11, have a lot of HP, and not go internal rail shifter your options are limited. The nice thing about the Gear Vendors unit is the gear spread is well matched for the Muncie Close Ratio. Your effective rear gear in OD is 3.20. Keeps a Built small block in a good useable RPM range @ 70 or 75 mph.
Old Apr 14, 2008 | 02:56 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I used to sell them for motorhome use. Can't say how well the Vette would do with that short a driveshaft (you need to cut off a foot). Could you make the pinion angle correct?
Old Apr 14, 2008 | 03:50 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Old Apr 14, 2008 | 06:27 AM
Belgian1979vette
I think the Muncie has some pretty good gear spread, which is fun to use and makes for a very stout unit. This is one of the main reasons for trying to keep it. The TKO has a deeper first which produces a granny low. Maybe not that it would be impossible but it would be low. Because of this the gear spread is larger and thus this trans is weaker, even without taking into account the fact that the M22 has another gear angle and higher nickel content which makes it even stronger.
The overdrive is only usable with first and fourth, second and third end up being the same ratio as resp. third and fourth in a normal M21/22, effectively making it a six speed...
I would go this route, but I don't even want to consider cutting up my trans crossmember or trans tunnel. Dimpling i could live with however.
Old Apr 14, 2008 | 06:30 AM
Belgian1979vette
From their perspective it could be easy. It will bolt right up but they apparently have no experience in a vette, which is why this could mean trouble. The transtunnel on a vette gets real small once behind the transmission.
Old Apr 14, 2008 | 09:19 AM
a1sensei's Avatar
a1sensei
They DO have experience with Vettes and even sent me photos of the install. They cut out either two or three places in the tunnel (I don't remember exactly). Then they put in the overdrive, some padding as a spacer and re-fiberglassed. They said later C3's with a metal tunnel could get away with denting the tunnel out (dimpling) but might still need some cutting. The install was obviously do-able, but as I said before, I PM'ed a forum member after I did a search for "Gear Vendors" on this forum. He was the only person I saw who actually had installed one. Seems his name was Wayne, but I don't remember exactly, I haven't seen him around in years. He said the install was difficult. God bless, Sensei
Old Apr 14, 2008 | 09:27 AM
fauxrs2's Avatar
fauxrs2
Dont know about fitment in a vette, I helped a friend install one in his big block Nova and it was fairly painless. Operation wise its bullet-proof as they come and works really slick.
To Gear vendors overdrive
Old Apr 14, 2008 | 11:55 AM
Belgian1979vette
I'm not going to cut anything up to install. So it will be a no go i guess
Old Apr 14, 2008 | 12:41 PM
GTR1999's Avatar
GTR1999
My buddy has one in his 78. My back hurts looking at that moster. It's hooked to an M-22 rock crusher in fact that I'm supposed to rebuild when I get some free time!! The DS is short and I don't know how he got it out but he did. He switched over to a removable cross member too. It bolts to the main case, the tail housing is removed.
If it were me I'd go with a 5 or 6 speed.
Old Apr 14, 2008 | 01:22 PM
Belgian1979vette
How many changes did he make to his tunnel Gary ?
