trailing arm removal
Old Apr 14, 2008 | 07:19 PM
HighHeat303's Avatar
HighHeat303
Default trailing arm removal
Ok ive been working on this for awhile. The problem is Im pretty sure my trailing arm is bent, becuase a monster MI pothole ate it. So im in the process of taking out the front bolt on the trailing arm, and it is most deff rusted in place. I tried all the dw40 i can and i really dont think this bolt is ever goin to come out. What do you guys do when you take these off? I was thinking a cutting tourch up in there to cut the bolt in half where the shims are. which would mean cutting the shims too. i have all the cotter keys out and the nut off the bolt, but the bolt just will not come through there. Any advice is appreciated. thanks in advance
Old Apr 14, 2008 | 07:24 PM
Scott Marzahl's Avatar
Scott Marzahl
Old topic found in "Search", remove the shims if possible then the easiest and fastest way is to use a Sawzal and cut the bolt on each side of the arm using a good bimetalic blade about 6-8 inches long.
Gordonm's Avatar
Gordonm
Sawzall!
Get yourself an 8 or 9 inch bimetal blade (preferably Lenox since I work for them) put a little lube on it and go at it. Should be out in a few minutes.
Old Apr 14, 2008 | 07:32 PM
A88FXRS's Avatar
A88FXRS
Pull The Shims Out Both Sides. Light Torch. Cut Bolt Both Sides Where Shims Were. Done In 5 Minutes.
Old Apr 14, 2008 | 08:45 PM
kdf1986's Avatar
kdf1986
Most of the responses from previous threads on this topic referred to the sawz all method of cutting them out.
kdf
Old Apr 14, 2008 | 09:05 PM
BB72's Avatar
BB72
5 minutes....5MINUTES?!?!?!?!?!?....in a perfect world. Do not get standard length sawzall blades...they must longer as previously mentioned.
Old Apr 14, 2008 | 11:14 PM
Bud Merrill's Avatar
Bud Merrill
5 minutes , as seen on tv
Old Apr 15, 2008 | 08:57 AM
Simmo's Avatar
Simmo
Im stuck on this problem too.
I hammered out one side but the other aint coming.
The shims dont come out as the are not slotted so I cant easily get access to the trailing arm bolt to saw it out. Almost looking like I need to take the body off.
Old Apr 15, 2008 | 11:29 AM
HighHeat303
Yeah Im thinking that im just goin to go ahead and torch it. unless I can get the sawzall blade in between the shims, when the new one goes in you can bet im goin to grease it so hopefully if i ever have to do this again it wont be such a pita. would be nice if it would just slide right out....
Old Apr 15, 2008 | 12:11 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
Do you have an air hammer. I got my left one out in about 3 minutes. The right one had a little more rust and took about 15 minutes but was still relatively effortless. Just spray it down good with PB Blaster and let it soak for a few hours before you start.
Old Apr 15, 2008 | 12:19 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Jeffery73 - did you chisel off the ends? Drive the bolt out? Don't quite have the visual picture here. Tks
Old Apr 15, 2008 | 02:05 PM
CCrane65's Avatar
CCrane65
Me and a couple of friends just did mine Sunday. The shims were rusted solid so we sprayed PB Blaster liberally often and worked the largest shims up and down until they came out. Tooks about 30 minutes or so. Lots of crap built up in the cavity that needed to be cleaned out so we could get to the bottom of the shims.
Once the shims were out a sawzall was used to cut the bolts on each side of the t/a through the bushings.
cc
Old Apr 15, 2008 | 03:14 PM
Steve Straus's Avatar
Steve Straus
When I did mine years ago, I went and got the biggest nail I could find at Home depot, heated it with a torch and bent it like this. This nail is like a foot and a half long. This way I could get a straight shot at the bolt and knock it out without hitting the fender. It moves the point of impact into the fenderwell and gives you much more room to hit it with a decent blow. It took me about 5 minutes to whap it out this way and I didn't have to cut anything. The bolts were rusted in badly too.
Old Apr 15, 2008 | 03:43 PM
BB72's Avatar
BB72
I can't picture that nail 1.5 feet long. Never seen one like that.
Old Apr 15, 2008 | 03:57 PM
fauxrs2's Avatar
fauxrs2
Sawzall - go right through the shims...
Old Apr 15, 2008 | 05:49 PM
HighHeat303
Alright thanks for the replies. I just got off of work and im goin to go give it a go.
Old Apr 15, 2008 | 06:00 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
8" sawzall blades are the ONLY ones to use. 6" are too short, 9" will hit the back of the pocket. Lennox and DeWalt are the only two 8" blades I've ever heard of - I used three DeWalts on my T/A bolts.
Old Apr 15, 2008 | 07:47 PM
rcread's Avatar
rcread
Yeah, you really need a BFH for that nail.
Old Apr 15, 2008 | 09:31 PM
72LS1Vette's Avatar
72LS1Vette
WD40 isn't going to do anything for rusted parts. Use either PB Blaster as others have said or get some Kroil which is supposed to be even better. If soaking with PB for a week doesn't loosen the bolts you will need to use the Sawzall. Buy good blades since I believe the bolts are grade 8. I use LOTS of PB on my cars and I still had to saw off the trailing arm bolts on the 72. Sometimes Mother Nature wins.
Rick B.
To trailing arm removal
