Pearl paint Q?
some lint or fuzzy SH*t landed on the hood with out me seeing
it till it was to late.
Can I color sand it out andspray a **** coat over it, then lay down the clear?? All the HELP
I can get will be helpfull.
Thanks in advance. glassman74
http://autobodystore.com/forum/forumdisplay.php?f=2
Assuming a base/clear system you can sand the panel and re-spray the base then clear everything. The re-coat time may have elasped by now in which case you need to scuff and re-spray everything before you put the clear on. Generally you need to clear within 24 hours.
