another diff. removal question.
Old Apr 15, 2008 | 09:03 PM
another-user's Avatar
another-user
Default another diff. removal question.
one bolt to go... the front bolt on the diff that goes through the bushings. the whole things is spinning freely, and i cant get anything ontop of the bolt head so i can break the nut free.
so.... any ideas?
Old Apr 15, 2008 | 09:18 PM
Paul71LT1's Avatar
Paul71LT1
I did two of these within the last year and you should have no trouble getting a box end wrench on the top bolt. I don't recall the size but may have been 5/8" or 11/16". You can't see it but feeling it should be all you need to get the wrench in place. When you reinstal be sure to torque the bolt to the proper value (I think it was 65 lb-ft) to preload the rubber bushing or you will get some clunking when you back up and go forward again.
Old Apr 15, 2008 | 09:24 PM
jhuff's Avatar
jhuff
Have you taken the main driveshaft out yet? When I did mine I couldn't get that part out until I had gotten the driveshaft out of the way.
Also, an offset box-end wrench will do wonders for those types of situations
Old Apr 15, 2008 | 09:32 PM
another-user
was planning on leaving the drive shaft connected to the transmission, but if its gotta come out...
Old Apr 15, 2008 | 09:33 PM
champs65's Avatar
champs65
I thought it was 9/16, but I just can't remember. In any case, I had no problems accessing area at all.
My driveshaft, I left it in.
Old Apr 15, 2008 | 09:57 PM
jhuff's Avatar
jhuff
I was planning on taking in my driveshafts to be balanced so there wasnt much of a decision to be made whether or not to take it out. If you are taking the Diff out you might as well get the driveshaft and halfshafts balanced at the same time.
Old Apr 16, 2008 | 07:42 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
Ditto on above about the box end wrench and leaving the drive shaft in. Replaced my old bushings last week with everything still attached. It took longer to clean up and paint the mounting piece than to replace the bushings.
Old Apr 17, 2008 | 12:56 PM
another-user
did you guys use some massively offset wrenches? mine have about a one inch offset, but theres no way i can find to get it on there, i keep hitting the storage bins, and its still another inch or 2 a way from even coming close to going on hte bolt head.
Old Apr 17, 2008 | 01:35 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I didn't have a problem getting to that bolt head, I think I might have come in on it directly under the driveshaft. I used the open end of the wrench to grab it, rather than the box end.
Old Apr 17, 2008 | 01:40 PM
pbcanney's Avatar
pbcanney
just one more thing in the way
Old Apr 17, 2008 | 02:12 PM
another-user
looks like im going to have to cut it out anyways. the bushings have collapsed in on them selfs so much that i cant get a wrench on the head. the bushings are pressed up pretty tight against the head.
Old Apr 17, 2008 | 09:00 PM
another-user
ok, last question here. i have the front bolt out (heated up the nut, and put a pair of vice grips on the threads and a wrench on the nut, poped off pretty easily) and the 2 Xmember bolts out.
sat there prying and hammering on it for 10-15 mins and theres very little movement. a few people mentioned putting a gear puller on there and popping it off that way. any one care to explain how they set that up?
Old Apr 17, 2008 | 09:27 PM
Racer11's Avatar
Racer11
I pried mine out with a 4 foot or so piece of round steel that was about a inch in diameter. I heated up the end and flattened it some for more bearing space. I stuck her in there and beared down on it and she popped. When you put it back in grease it, inside the cup and every where with some waterproof grease.
Old Apr 17, 2008 | 09:29 PM
stinger12's Avatar
stinger12
Even better - cover the bushing hole in rtv so you completely seal out water.
Old Apr 17, 2008 | 09:45 PM
Racer11's Avatar
Racer11
There ya go, grease her up and seal her up,
Old Apr 17, 2008 | 10:43 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
1) put the crossmember bolts back in about halfway.
2) get a two-jaw adjustable gear puller.
3) put the threaded shaft on the bolt, with the adjustable ears hooked on the crossmember. It'll pop loose without much effort.
You need the bolts back in both to push against and to keep the whole thing from flying out when it comes loose.
Old Apr 17, 2008 | 10:52 PM
another-user
sounds good.
that also brings up something i was wondering about. how long are these bolts supposed to be? i swear mine cant be much over an inch. they just seem so short for how much theyre holding in.
To another diff. removal question.
Old Apr 18, 2008 | 12:47 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
sounds good.
Sounds about right. If they're too long, they'll run through the cone mount and hit the frame above it. Not good for clamping power. The actual interface area in the cone is only about the thickness of a regular nut, so extra length is wasted anyway. If you think about it, it's not really holding much - the weight of the car and the tension of the spring usually keep it jammed in place quite nicely.
Old Apr 18, 2008 | 09:34 PM
assassin 420's Avatar
assassin 420
Batman's technique worked perfect for me. Don't forget to put the bolts part way in. Both sides on mine popped violently when they let go. The auto part stores loan the pullers for free.
Old Apr 18, 2008 | 09:47 PM
another-user
depending on the time and weather, ill be doing this tomorrow and sunday. ive got the gear pullers out and sitting under the car and waiting to go right now.
