Fan clutches
Old Apr 18, 2008 | 01:09 PM
Scott Marzahl's Avatar
Scott Marzahl
Default Fan clutches
I'm curious is anyone has used any aftermarket fan clutches like a Hayden with any long term success? The fan clutch I just removed from this kid's car is an unknown aftermarket with silicon leaking out of it from beneath the coil. I typically only use Delco parts for stuff like this but this kid is short on cash and the Hayden is half the cost but you typically get what you pay for too.
Thanks,
Scott
Old Apr 18, 2008 | 01:17 PM
Durango_Boy's Avatar
Durango_Boy
I have had mixed results. I have used Hayden clutches in some of my Dodge truck projects, and one or two have been fine and one has failed. Seems like a good quick fix if he's on a budget, but recommend he replace it with a good Delco clutch when he can afford it.
Old Apr 18, 2008 | 01:20 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Yep, it's tough to be OEM parts.
Old Apr 18, 2008 | 09:10 PM
mikep3's Avatar
mikep3
Default NAPA Fan Cluch
I used this one because Autzone and Adavaced did not have stock.
http://www.napaonline.com/MasterPage...-+Thermostatic
Never looked to see were it was made, but two years and it works although it is cool up here in Syracuse only crused two days in the low 90's with a/c on.
Old Apr 18, 2008 | 09:35 PM
Scott Marzahl
Thanks all, talked him into a AC Delco unit.
Old Apr 18, 2008 | 10:08 PM
rihwoods's Avatar
rihwoods
Hayden dropped thier "lifetime" warranty some years ago...absolute junk....
To Fan clutches
