1982 steering control valve
Old Apr 16, 2008 | 09:26 AM
Brian Whiting's Avatar
Brian Whiting
Default 1982 steering control valve
Has any one out there ever changed a power steering contrl valve on an 80-82...mine is leaking profusly...dont know if its a line or the whole valve...all I do know is that Im losing the whole bottle in about 2-weeks at a static sit..any suggestions..BW
Old Apr 16, 2008 | 09:39 AM
crazywelder's Avatar
crazywelder
First, go under the car and pinpoint where the leak is. If you look at the valve, you'll see that it has 2 castings bolted together in the center. The casting half with the zerk fitting contains chassis grease to lube the ball stud on the top, the other half contains power steering fluid under pressure from the pump which provides power assist. There is an internal seal where the 2 housings bolt together which prevents p/s fluid from getting into the grease side of the housing. If your leak is p/s fluid, fluid is probably getting past the seal and coming out of the ball stud area on top which is in the grease side of the valve.
Rebuild kits are available as well as rebuilt and new valves. They are not real difficult to rebuild, however there are a lot of small parts inside and as long as you pay attention during disassembly and reassemble the valve correctly it will work, provided the spool and housing are not badly worn. There are some free tech materials available at tjis link in case you don't have a GM manual.......... http://jimshea.corvettefaq.com/?page_id=4
Old Apr 16, 2008 | 10:09 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
When you reinstall the unit, don't get carried away greasing it. Too much grease can damage the seals and you'll be right back were you were.
Old Apr 16, 2008 | 01:34 PM
7T1vette's Avatar
7T1vette
The leaks are telling you that "it's time to rebuild/reseal" the whole power steering system. The worst thing you could do is just repair the part(s) that are leaking badly now. The whole system is old and all the seals are significantly worn. And, once you get down there and work on that oil, nasty mess, you don't want to have to do it again! Rebuilding the pump and valve and replacing the lines is an easy (but messy) job. The worst part is cleaning up the junk from the parts once you remove them. This is one of those jobs that it pays to do it yourself. A rebuild kit for the valve is less than $20 and is just a few seals. The pump has a couple of seals and a big O-ring. Not that big of a deal, and service shops charge a bundle for doing the same thing.
To 1982 steering control valve
