Vacuum Ports on a Q-Jet
Old Apr 16, 2008 | 10:37 AM
tommyleea's Avatar
tommyleea
Default Vacuum Ports on a Q-Jet
I have brought up this issue before, but the more I work with the Q-Jet, the more questions I have. Just trying to understand the vacuum ports. For example, the vacuum port for the primary vacuum break is just about in the middle of the carb, but it has constant vacuum. (at least mine does). It seems that with its placement, it would be ported vacuum. Is there any type of picture that shows what ports are ported vacuum, and which are manifold vacuum? Thanks for your help as always. Cheers..
Tommy
Old Apr 16, 2008 | 01:28 PM
7T1vette's Avatar
7T1vette
You can't tell, just by the location of the port on the carb casting, whether the feed passage on the inside of the carb is above or below the throttle plates. The ports are not necessarily 'fed' by a direct drilled hole. The best way to tell whether you have "timed" (ported) vacuum or "direct" (manifold) vacuum is to take the line off of a port and put a piece of paper across the port to see if vacuum is present [or not] at idle.
Old Apr 16, 2008 | 11:55 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
...or hook up a vacuum guage.
To Vacuum Ports on a Q-Jet
