tach problem ugh
Old Apr 16, 2008 | 09:41 PM
LADAN79's Avatar
LADAN79
Default tach problem ugh
79 hei, key off reads 1500, key on reads 0, hit the starter
tach goes up with the rpm about 1000 until the engine starts then it drops to 0 and sits.
pulled the dash out and the circut looks ok ohmed the traces and didn't find any opens,
same results with the filter in and out.
just for fun hit the starter with the motor running and the tach tried to work,
Stumped
Old Apr 16, 2008 | 10:31 PM
65GGvert's Avatar
65GGvert
Sounds like the ignition switch has a bad contact or connector, if you hold it to start and the tach works. The more likely culprit is the tach board mounted on the back of the tach by three nuts. Not the printed circuit flimsy thing behind both, but the small board mounted directly to the tach. Does that board have a black burned spot on it?
Old Apr 16, 2008 | 10:54 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
To eliminate other issues, (shorted wire, ground problem and any other issue) and you have the tach out of the car you can hard wire it.
Run 12 volts from the alternator to the power side, a ground to the engine, and then run a pulse wire from the distributor to the tach.
Doing all this while holding it in your hand you can fire up the car and see if it’s a working properly without any outside interference.
Old Apr 16, 2008 | 11:13 PM
LADAN79's Avatar
LADAN79
65, there isn't a board
WC, thanks, I'll give that a shot tomorrow
Old Apr 17, 2008 | 01:42 PM
1Z87L8's Avatar
1Z87L8
you should have one of these mounted on the
back of the tach itself
http://hometown.aol.com/coronet69/page18.html
Old Apr 17, 2008 | 10:48 PM
65GGvert's Avatar
65GGvert
Never saw a 78 or 79 without a board, is the hei different? How does the tach make contact with the voltage/ground/pulse? It should have three long screws that plug into the flexible printed circuit ***'y. The tach board should be mounted on those three long screw with nuts to make electrical connection. Does the fact that it is hei somehow eliminate that board? P.S. the board is not visible unless you remove the six torx screws from the black cover around the tach/speedo, then the three torx screws from the tach and pull the tach out of the ***'y from the front, the board is attached to the tach and comes out with it.
Old Apr 17, 2008 | 11:20 PM
0Willcox Corvette
Former Vendor
I think all he is seeing is the three connectors for the tach! I don't think he has opened it up to see the circuit board.
W
Old Apr 18, 2008 | 02:07 PM
LADAN79's Avatar
LADAN79
tried running separate tach, ground, and power = no go,
sorry didn't know the board was inside the housing,
learning experience, found out the tach reads while the engine is cranking even with the tach wire disconnected but once the engine fires the tach drops to zero connected or not.
I think everything appears good up to the gauge, I pulled the board and the component side looks good, the back side has a overheated spot near a resistor and a couple diodes but no burnt traces.
I would feel better about buying a new board if there was more damage, but I guess at this point I don't know what else to test.
I've cleaned all connections, for geewizz I even switched ignition moduals.
any suggestions or just place an order.
Old Apr 18, 2008 | 08:37 PM
'75's Avatar
'75
You need a new circuit board. I don't recommend the one from ecklers.
Old Apr 18, 2008 | 08:54 PM
A88FXRS's Avatar
A88FXRS
i agree. i still have two new ones in the box that they wont make good on, let alone the labor and ag to change them.
Old Apr 18, 2008 | 10:40 PM
0Willcox Corvette
Former Vendor
When the ignition key is turned in the on position with out starting the car the tachometer is powered up! When powered up the tach should go to zero instantly. This is the same as doing a hardwire test! If you run 12 volts to the positive side and a verified ground to the ground side, the tachometer should instantly go to zero!
Once you introduce the pulse wire from the distributor then the tachometer should start reading the signal. (and working).
With your burned spot on the board I have to agree the board is done! They are easy to install and are pre-calibrated!
Willcox
Old Apr 19, 2008 | 12:00 AM
cruise83's Avatar
cruise83
i have a 79 and this is what i did. I removed the housing after removing the tach face and the board, I left the speedo in place after disengaging the cable. Bought a new board from corvette central...how ever you feel confident buying from...replaced the board and replaced the thin circuit board on back on the housing, replaced any burned out bulbs. I tested the tach board by touching a 9 volt battery to the 12v and ground screws...if the board is good it will zero out. put everything back and all was good as new.
Old Apr 19, 2008 | 06:47 AM
65GGvert's Avatar
65GGvert
The tach board can be bad and it will still zero out with voltage applied. Be sure you get a board that is precalibrated for the 78/79. Willcox sells them. I also have a new one in the box that I bought from Willcox that has never been installed. If you can't find one, or want to buy mine, pm me and we can talk. You don't have to remove the speedometer or the ***'y that holds the tach/speedo. You already have yours apart apparently, but if not, you remove the front plastic lens, the black cover around the tach/speedo as I mentioned before, then the three screws holding the tach, it pulls out separately with the board attached and you don't have to disconnect and reconnect the speedo cable. I can have mine out in about three minutes now that I have done it a couple of times.
To tach problem ugh
