Need Help Please
Old Apr 18, 2008 | 06:57 PM
nastee383's Avatar
nastee383
Originally Posted by 69Vett
It could be a starter solinoid problem, usually they fail more frequent,
once they start to fail.
If you open a starter solinoid it is like a big copper washer,
about 1.5 Dia. this sorta rotates around from use, after enough wear it will start to Not make contact, thus the tapping of the hammer vibrates the contact and then transfers power,
you can actually remove that copper washer and flip it over,
and presto you have a new starter solinoid.
clean up the screw contacts, form the power wires.
69VETT
Hopefully thats not the issue. The starter is about 1 month old. 99% of the time the motor fires right up even when its cold. I mean turn the key and BAM, its fired up.
