Fuel Pressure
Old Apr 18, 2008 | 07:48 AM
A8skyhawk's Avatar
A8skyhawk
Default Fuel Pressure
I'm still running the stock '69 fuel lines to a BG 750. The car runs and feels great. However, my fuel pressure gauge installed just before the carb inlets (after the stock inline fuel filter) stays around 0-2 psi and drops to 0 when rev'd.
Is this normal with the guage installed past the inline fuel filter (with return line) or is my gauge defective? It's also a fairly new ZZ4 & fuel pump with less than 5000 miles...
Last question... That is a fuel return line off of the filter right? I think I read somewhere that its a vapor return line.. but I can't remember.
Old Apr 18, 2008 | 01:00 PM
Mike Ward's Avatar
Mike Ward
Put a circle of back tape over the face of the gauge. Problem solved.
Old Apr 18, 2008 | 01:31 PM
pbcanney's Avatar
pbcanney
dont sound right to me.
If the gauge is accurate you're always toying with running too lean. ZZ4 pump? is that correct for the engine or is it an upgrade? I'd be curious to know if maybe the wrong rump rod is in there.
But, Mike's answer works too. (and faster)
Old Apr 18, 2008 | 04:53 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Default fuel pressure !
If your running the orginal stock fuel line from a 69.
and you can not pump up to 5 psi, I would bet your gas line is leaking.
Gas leaks are not to be taken lightly, in a plastic car.
I highly recommend you find the problem.
I would cap off the carb and check your fuel pressure.
almost every orginal 69 gas line is a rusted steel line, and leaks.
forget the tape ideals... FIX IT.. 69 VETT
Old Apr 18, 2008 | 05:53 PM
Mike Ward's Avatar
Mike Ward
Gimme a break here. People add aftermarket gauges to their cars, then fret over the readings they get- and then try to fix something that's not broken.
A defective gas line will always leak outwards (drips/smell) LONG before it leaks badly enough to suck air in and starve the pump.
Look at the endless string of posts where people spend most of their time staring at either the water temp or oil pressure gauges or both. The car apparently works fine, but they feel the need to stare at the gauge wishing it read something different.
GM put all the gauges in C3s for 'bling', not for necessity. Most of GM products of the era using similar engines had no temp or pressure gauges and somehow miraculously survived.
Adding more gauges now to measure more parameters achieves what?
A fuel pump in bad shape will show up with an engine going flat at max load and max revs. The poster indicates his car runs fine.
Old Apr 18, 2008 | 06:08 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If you have a fuel leak, you will smell it pronto. And if it ain't broke, don't fix it. Just my 2 cents.
Old Apr 18, 2008 | 06:28 PM
A8skyhawk's Avatar
A8skyhawk
I did put the gauge into the engine compartment mostly for looks... hey.. why not... It does look pretty sweet all chromed out on the feed line. Additionally, if I do run into troubles down the road thats an easy functional tool to rule out fuel feed problems.
I do not think I am leaking gas anywhere... but I will double check... the gauge read the way it did from day 1 and the car runs fine so I'm pretty sure from what you guys are saying its a defective gauge...
It just interested me because I didn't know if it was a possibility that the return line is affecting the pressure readings.
69Vette- No fear I have ordered a replacement gauge... Mike... In the mean time I have a black piece of tape over it with white writing that reads "INOP"
Thanks for the help
Old Apr 19, 2008 | 01:21 AM
jack 69's Avatar
jack 69
if your car runs fine then don't worry.... but i had two of the oem filters plug up in a very short time... i have a new fuel tank, lines, pump... saved the filters and checked them later and they were fine.... i think it has something to do with the blend of fuel in Calif.... Edelbrock has warning about the fuel in one of there carb instruction sheets....
Old May 9, 2008 | 10:47 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I purchased a dual-feed chrome fuel line with filter and gauge from Summit Racing.
The only problem I have encountered is the gauge reads 5-6lbs then, as the engine warms up, it drops to 2lbs. The engine runs perfectly....Called Summit and they said that as the engine warms up, the guage will show a drop in pressure. Is this true??...I have never heard of that before. I have owned 2 Holley gauges and they never showed a drop in pressure....but just in case, Summit is sending another gauge out Monday and I should get it Wednesday. Just checked it (engine cold)...shows 5 lbs.....will check it tomorrow.
Has this ever happened to anyone (gauge shows a drop in pressure as the engine warms up...)
To Fuel Pressure
