69 dash brake light
Old Apr 19, 2008 | 10:11 PM
mdetch's Avatar
mdetch
1st Gear
Default 69 dash brake light
I have a 69 350/300 automatice and the break light on the dash came on. I checked the emergency brake switch but it is working. What else could be the problem?
Old Apr 19, 2008 | 10:58 PM
'75's Avatar
'75
I believe the switch at the proportioning valve can also turn on that light if either the front or rear brakes fail. It's probably located on the frame under the master cylinder. Have you checked the brake fluid?
Old Apr 19, 2008 | 11:46 PM
A8skyhawk's Avatar
A8skyhawk
Old Apr 20, 2008 | 01:13 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Probably a leak or other problem in either the front or rear brakes.
To 69 dash brake light
