The correct push rods?
Old Apr 20, 2008 | 07:48 AM
njsting76's Avatar
njsting76
Navigator
Default The correct push rods?
Does anyone know if the stock push rods on a 1976 L48 350 engine; are they harded steel so they can be used with harded push rod guide plates on a set of new heads? If not would you recommend using the stock push rods?
Old Apr 20, 2008 | 09:16 AM
Durango_Boy's Avatar
Durango_Boy
No, they are not hardened and you do need new ones to use with those guide plates.
Old Apr 20, 2008 | 02:19 PM
Little Mouse's Avatar
Little Mouse
Stock length hardened pushrods CCA-7812-16 = $29.95
www.summitracing.com
Old Apr 20, 2008 | 06:07 PM
stingr69's Avatar
stingr69
These are the ones I use with guideplates.
GM Performance Parts #12495491 (available from Scoggin Dickey for $39.95). In my opinion this is a superior design when compared to the cheaper pressed-in ball end style.
-Mark.
Old Apr 20, 2008 | 07:18 PM
Little Mouse
Comp Cam's, # CCA-7812-16, stock length, hardened for guide plates, welded in tips . Summit has some that are hardened, welded tips in there brand, $26.95
SUM-G6400 no telling who"s pushrods summit is repackaging.
To The correct push rods?
